65 Converible hipo?
65 Converible hipo?
Postby kr3760 » Sat Nov 25, 2017 9:45 am
Has anyone seen a 65 Hipo convertible? How do you tell the difference from the reg A code motor to the Hipo motor? Thanks if advance for your response
kr3760
Re: 65 Converible hipo?
Postby Rocket989 » Sat Nov 25, 2017 10:47 am
Welcome aboard!! Nope. K-code in Comets/ Falcons doesn’t mean same as ‘Stangs. The easiest way to (start) ID’ing a real Hi-Po motor are the exhaust manifold & harmonic balancer. I’d have to look at a lot more stuff before I’d buy in - lots of info via Google!! :lol: :lol: :mrgreen:
Rocket989
Postby kr3760 » Sat Nov 25, 2017 11:05 am
I understand about K code vs A code. From that there are two A code motors for 65 Correct. Solid lifter. Will the balancer be the same as Mustang?
kr3760
Postby poboyjo65 » Sat Nov 25, 2017 11:16 am
No verts came with hipo motor.'' A'' code for 65 comet is the 225 hp super cyclone motor with 10.5:1 comp flattop pistons that burned premium fuel only. with hyd. lifters.
347, 4sp, 9''......
JOHNO
Postby Rocket989 » Sat Nov 25, 2017 3:17 pm
Yep - the only solid lifter 289 was the Hi-Po. Balancer is same as the ‘Stang but different exhaust manifolds (still unique to the Hi-Po engines). The ‘Stang parts won’t fit!
Rocket989
Postby comethead » Sun Nov 26, 2017 2:59 am
65 Hipo 289 had a manual choke Autolite carb. No vacuum advance distributer. Heads with screw-in studs.
Thicker main caps and probably a VIN stamped somewhere on the bottom of the block. 4 speed only but a Fairlane Hipo could have had an auto trans.
No convertibles unless it was a super top secret special order. In that case I think you’d need a build sheet to verify.
Image<click
1965 Caliente HT
289/4 speed
Postby 65 hipo » Mon Nov 27, 2017 12:33 pm
The only way to know for sure is to have the build sheet. There are some other clues, like a special DCO number (but not always mean HiPo), no power accessory’s, top loader 4 speed, bolted export brace, 9” rear end. Do you have any pictures of the car? Like under the hood.
1965 Hi-Po Cyclone
1995 Mustang GT
65 hipo
Postby kr3760 » Wed Nov 29, 2017 3:56 pm
I will post pics when I get back home this weekend. Car is a rotisserie resto. 4spd. awesome car. asking 25K? Seems like a lot of $$ however can't buy one and build it for that. Thoughts?
kr3760
Postby Groover » Wed Nov 29, 2017 5:16 pm
kr3760 wrote:I will post pics when I get back home this weekend. Car is a rotisserie resto. 4spd. awesome car. asking 25K? Seems like a lot of $$ however can't buy one and build it for that. Thoughts?
Yes, maybe a little high, but you probably can't build it for that (will know better when you share the photos).
Hey HiPo guys, why does the distributor for HiPo not have vacuum advance. So it's entirely mechanical? does it achieve enough advance at highway speed?
Postby A/FX » Wed Nov 29, 2017 7:59 pm
Hey HiPo guys, why does the distributor for HiPo not have vacuum advance. So it's entirely mechanical? does it achieve enough advance at highway speed?[/quote]
I believe very early HiPo 289’s had a vacuum advance distributor, for sure 65 and later used a non vacuum unit. I have one for my Boss engine, when I used it in my 302/triPower engine I set it up for total advance at above idle engine speed. The internal weights and springs determine the amount of advance, when the distributor is timed it determines when the advance peaks. Mine worked well and I expect it to work even better in the Boss because I am converting it to a Pertronix.
I have an Accel dual point also but that will not be used this time around.
'64 Cyclone
Postby 65 hipo » Tue Dec 05, 2017 12:26 pm
All 289 HiPo’s had mechanical advancing distributors. With vacuum that is created by the cam, distributors and brakes can be affected but the loss of vacuum with a more aggressive cam profile. Although the stock cam in the HiPo should have been fine I would think.
1965 Hi-Po Cyclone
1995 Mustang GT
65 hipo
Postby comet guy » Wed Dec 06, 2017 8:32 pm
The way this looks it's well worth $25,000. Like you said you can't built one for that let alone fine one
comet guy
Return to 64 - 65 Comets
