65 Comet with 390
Re: 65 Comet with 390
Postby loman » Mon Jan 07, 2019 8:49 pm
Thanks Lou. If you can post the part # for the SEM stuff that would be great. I'll suggest it but I think I am being overruled by the crew chief and I'm just going to let him do what he wants instead of debating with him.
Over the weekend I was able to finish welding the tunnel in. And today I found out the rocker arm shaft shims finally showed up, so I will go over to the crew chiefs house tomorrow and check it out.
loman
Postby popscomet » Tue Jan 08, 2019 12:06 am
you hang in there with that crew chief,,,,POP
Postby Lou's Comet » Tue Jan 08, 2019 6:38 pm
loman wrote:Thanks Lou. If you can post the part # for the SEM stuff that would be great. I'll suggest it but I think I am being overruled by the crew chief and I'm just going to let him do what he wants instead of debating with him.
SEM # 29392 black seam sealer. Works well and is only like $14/$15 @tube
Postby loman » Tue Jan 08, 2019 9:38 pm
popscomet wrote:you hang in there with that crew chief,,,,POP
I'm trying pop. I know I'm lucky to have a crew chief. We tend to have different ways of doing things and butt heads. But at the end of the day we have a beer together and all is good.
loman
Postby popscomet » Wed Jan 09, 2019 2:01 am
you dang tooten that's the way me and DWAYNE are......nothin comes twix us !!! been that way since he was a little boy !!you can cut my right arm off,,,as long as DWAYNE is around...I don't miss it !!!...…..pop
Postby loman » Sun Jan 27, 2019 6:12 am
Nothing really picture worthy, but we reinstalled trans yesterday and got driveshaft measurement. I bought some brake line so I can rerun the passenger front line and install line lock. Rolled car outside and pressure washed engine bay. Set front seat in and got rough location for the shifter. After some beer thinkin we ordered different rocker arm adjusting screws. We are going to swap out the ball adjusting screws and replace them with cup style adjusting screws. This way we can order a one piece pushrod and not the goofy cup style pushrods.
loman
Postby loman » Sat Feb 02, 2019 8:12 pm
Update, we got the drive shaft made. I finished the mock up of line lock and new front brake line. I just need to finish mounting the line lock and bleed brakes. We also made a new dipstick tube that now clears the crank, oil pump, and windage tray.
We got the new cup style rocker arm adjusting screws and went to measure for push rods. The crew chief called Crower the other day to verify the FE lifters we purchased will pump oil up through push rods. They told him we were good to go. Well, today we started to measure for pushrod length and notice that the lifters do not have a oiling hole where the push rod sits. The factory FE lifters do not have that hole either because they are designed to oil from the rocker arm shaft assemblies. So we are thinking the Crower tech steered us wrong. I have been warned more than once to only trust FE info only from a person who knows FE's and not your general tech help person. I'm not saying Crower is wrong, but I am definately going to double check every thing. Tomorrow I plan on getting some old lifters from a 351 or 460 I have laying around and do some comparing to the stock FE lifter.
loman
Postby loman » Sun Feb 03, 2019 8:58 pm
Checked out the new driveshaft today and found out the wrong u joint was installed or it was made wrong. We gave them my old rear unjoint that was in my old driveshaft. We asked them to make new driveshaft and the rear unjoint needs to match the one we sent along that was marked with tape and a paint marker. So crew chief is going to take it back this week.
Crew chief is also going to call Crower again and discuss lifters. We did some comparing and looked at jegs and summit and we came to the conclusion that all ford lifters sbf,BBf, and Fe are the same size physically only the fe lifters have no provision to send oil up through the pushrods.
loman
Postby loman » Sun Feb 10, 2019 8:55 pm
I put the mock up motor back in car today so I can make an engine travel limiter. After I got it in, I didn't feel like getting under the car so I decided to mock up the water pump and alternator. I have 2 different FE water pumps, the only difference is one has a locating pin which I'm guessing is for the top alternator bracket. The other has a threaded hole. I chose the one with threaded hole so I have a place to mount the adjusting bracket for the alternator. I also only have 1 of the original alternator brackets but I found one in my junk pile that I can make work with a spacer. Then I took my spare water pump pulley and put it on. With the way the pump is cast the pulley rubs on it. So made a spacer to shim it out for clearance. Also the Crew chief went back to drive shaft builder and was able to get the correct rear joint to fit the rear end. Making slow progress, just need to concentrate on the push rod situation so we can button up the motor.
loman
Postby loman » Sat Feb 16, 2019 11:36 pm
Not much progress was done today but the crew chief and me came up with a plan for the cooling system. We went through our radiator pile and found one we think we can make work. Crew chief is going to flush it out and pressure test this week. If it is good, we will use that radiator, a pusher fan (crew chief has a couple laying around), with a stock water pump with the cheap Moroso style water pump that I have a couple sitting on the shelf.
loman
Postby popscomet » Sat Feb 16, 2019 11:42 pm
that's cool....always try to use what you have in stock on the shelf....that's why you saved it in the 1st place !!pop
Previous
Return to 64 - 65 Comets
cron
