Fairlaniac's 1964 FE Pro Street Project
fairlaniac
Re: Fairlaniac's 1964 FE Pro Street Project
Post by fairlaniac »
poboyjo65 wrote:Doug is it going to be race only or street & strip?
You got it going on, nice pace ! I use to work for a guy, at least once every day he would state, rather loudly & just out of the blue, "professional people doing a professional job!"
More street, occasional strip. You always gotta check how fast it is. Everytime I step in the garage I do at least a little something. Even if for 5 minutes. One day it'll be done.
Doug Bender
1964 Comet Caliente
1966 Fairlane 427/4 Spd
[ Everytime I step in the garage I do at least a little something. Even if for 5 minutes. One day it'll be done.[/quote]
Thats the best way,it is so easy to get burnt out on work......good luck !! POP
6667fan
Post by 6667fan »
Looks like you are doing it up right Doug. Good luck. Don't forget to keep the FE crowd informed. JB.
pro64
Post by pro64 »
Hey doug Hows the welding coming on the hot rod LINCOLN :D
pro64
Post by pro64 »
hey doug how about a update 8)
fairlaniac
Harry, Here you go. I've fitted up the FE block in the engine bay via custom front mounting plates and a mid-plate. A little roll cage work, getting the rear and tires in place, trans mount and some frame work. In no particular order here are some pics from the past month or two.
Doug Bender
1964 Comet Caliente
I see you have a long shaft toploader like mine. mine came from a 70 fairlane/torino -RUG-BA & had a 31 spl output shaft, though when I decoded it said it should have a 28 spl., kinda curious how many splines yours has & what code it is. & you have about a foot for different shifter locations. It's all looking good!! :D
pro64
Post by pro64 »
Hey doug that's some nice work, looking good. Nice job on the backhalf . what size are the back tires.
fairlaniac
poboyjo65 wrote:I see you have a long shaft toploader like mine. mine came from a 70 fairlane/torino -RUG-BA & had a 31 spl output shaft, though when I decoded it said it should have a 28 spl., kinda curious how many splines yours has & what code it is. & you have about a foot for different shifter locations. It's all looking good!! :D
The trans is empty, just a broken case and tail housing bolted on. It's a C6OR tail housing from a Fairlane.
Doug Bender
1964 Comet Caliente
pro64
Post by pro64 »
Hey doug do you have a body shop all picked out. And will you be welding in the floors, I ended up with two sheets of 16 gauge for the floor pans , driveshaft tunnel, and transmission tunnel. A lot of welding for sure.
fairlaniac
pro64 wrote:Hey doug do you have a body shop all picked out. And will you be welding in the floors, I ended up with two sheets of 16 gauge for the floor pans , driveshaft tunnel, and transmission tunnel. A lot of welding for sure.
My buddy's kid will do the body work. https://www.facebook.com/butchsbodyworks/
Doug Bender
1964 Comet Caliente
fairlaniac
Got it to be a roller and brought it outside for some fresh air and sunshine.
Doug Bender
1964 Comet Caliente
looks great,,,,it flat shows your talent.....pop 8) 8)
WOW! :D Baby got stance! :P
That is one cool '64 Comet.
