Once you cut the shock towers out it is all downhill from there That and the front core support and trunk floor and...Groover wrote:nice work, Mike. You have the nerve that I don't have... yet...
Groover your build thread helped me to get going just so you know as did numerous people on this Forum, seeing someone do something takes a lot of mystery out of it.
Welding pretty sure, if I could weld I wouldn't need to grind, but if you can't weld one needs excellent grinding skillsSASSY wrote:So in your most humble opinion do you think talent with the welder or with the grinder is most beneficial?
So for the most part using an old HF 110 welder and I haven't welded in a month and a half at least, I think I did ok not blowing holes, it doesn't hurt that the lip edge is 18 gauge either, really the only places I had trouble with was near thin rusty spots (blowing holes that is) and I was able to weld the hole back shut. The tell-tell will be next when I am welding the body parts back together. (I hope I don't run out of gas, it is getting pretty low)
Thanks guys, I am really happy to be getting this done, I know it appears to be delaying the flip but my uncle who is going to come up and help me is gone for Christmas visiting his daughter and I want to do the inner wells while it is flipped up.
