Jims65cyclone wrote:Then the villagers show up with their pitchforks and blazing torches and make you turn it off and go to bed.
Probably be villager, just one and you don't want to get on her bad side
Jims65cyclone wrote:Mike. I can just imagine when the time comes to fire it off for the first time.
I might just record the occasion
Sometimes I catch a break, by not breaking anything
I took my rear glass out today, didn't chip it, crack it or break it into tiny little bits. I have dad's truck sitting in the shed so I put the glass in the cab on the seat.
The second break I got was my window frame/channel is mint, looks like 1964 factory fresh (like this all the way around) That black insulation(?) that is under the package tray was nasty, it just turned to dust basically. Also that grey sealer is good stuff, still sticky (very) after 55 years.
I don't know if this is an area that is prone to rot or not but I survived somehow, finally something I don't have to repair
I also got the air tank mocked up into the car, I know you can't see it here but it is bolted to the rear package tray, I need to find some flat topped bolts to replace the bolts I have sticking out of the package tray I know I have seen them someplace.
It really tucks up in there I would like to think it will be hidden but there is a bunch of plumbing to go on there so no such luck.
I cut some little mounts for the compressor to sit on and I will weld them to the floor. This is so I can get nuts on the bottom of the bolts in the base, right now it has self tappers holding the compressor, I will tack it and remove the compressor and then final weld it down.
I am going to try and find some aluminum plate to divide the trunk from the cabin and will make it screwed in so access to the compressor will be a little easier than having to crawl into the trunk.
Will probably get the rest of the air ride components at least mocked in and get my rear bags reinstalled so I can get the back of the car off of the jack stands again.
