Looks good and solid under the dash. What did you use for paint?
Wiring replacement
Re: Wiring replacement
Its in pretty good shape under there. I used Eastwoods rust encapsulater.lavron wrote:Looks good and solid under the dash. What did you use for paint?
Len
Anyone have any advice on which red paint to use for interior applications? Does anyone make paint in this color or do I just match it up as best as I can?
Here is red for a mutsang
http://www.mustangsunlimited.com/itemdy ... y=EMUSTANG
Here other colors on that site,I saw a dark red. other mustang sites may have pics?
http://www.mustangsunlimited.com/SubCat ... J64&grid=N
You could find a color chart to look at stang colors to be more sure about it.
free shipping so you could order a can & if it looked good enough order more. for the price difference & if your not so picky you could just try to match it with something cheaper from the parts store.
Keep the pictures coming. I am about a month away from starting my re-wire and have decided on the Ron Francis kit also.
Thanks,
Trent
Thanks,
Trent
column looks good! & pedal. How do you like those taylor plug wires? I've had 2 sets like those & I think they are the easiest I've ever had to remove from the plug. easy to twist to break the seal & easy to pull on off after that. makes checking plugs much easier, especially in tight places like on comets.
Thanks Johno. I like the taylor wires. Youre right... easy on and easy off.poboyjo65 wrote:column looks good! & pedal. How do you like those taylor plug wires? I've had 2 sets like those & I think they are the easiest I've ever had to remove from the plug. easy to twist to break the seal & easy to pull on off after that. makes checking plugs much easier, especially in tight places like on comets.
