Header install
geralde
Header install
Post by geralde »
I am in the middle of installing a set of Dougs Tri-y headers on my 64. The engine is a 302 ho with an early c4. The headers are the automatic version. The driver side was too easy but the passenger looks very tight. Should I install the passenger side first? I have the engine lifted and am installing from the bottom. Have the steering linkage all dropped and the roller idler off. Thanks in advance. :D
geralde
Re: Header install
Post by geralde »
Well looks like I was only one cuss word away. Actually lowered the engine and it went right in no issues.
Re: Header install
Only one cuss word for a header install DARN good! :D That would be a record for me.
geralde
Re: Header install
Post by geralde »
Using my Ron Morris knock off motor mounts, I ended up with about 3/8 clearance in all the tight spots. Is this about right?
Re: Header install
geralde wrote:Using my Ron Morris knock off motor mounts, I ended up with about 3/8 clearance in all the tight spots. Is this about right?
dont know. I wish I had 3/8! :lol:
Kcrclw
Re: Header install
Post by Kcrclw »
Geralde,
Where did you get your Ron Morris knockoffs?
Thanks,
Kevin
geralde
Re: Header install
Post by geralde »
geralde
Re: Header install
Post by geralde »
Well back on the Comet again and It appears one of the header tubes is within a 1/2 of the fuel line. This is a new 3/8 stainless line. Should I move it or wait and see if it's a problem. Thanks.
Re: Header install
I made a little heat shield from aluminum angle iron for mine.alum is a good heat dissipater. Ceramic headers are cooler .
geralde
Re: Header install
Post by geralde »
They are ceramic but seems awfully close. I may cut the line and splice it and either go through the channel or to the other side away from the headers. Everything you do drives something else if it's not stock. Just a thang as we say around hear.
Comechero65
Re: Header install
Post by Comechero65 »
If you like having vapor lock shutting you down on the road then just leave it as is. I never want a fuel line any where near the exhaust. Get it as far away as possible. Easier to move the fuel line then the exhaust.
Re: Header install
Post by Rocket989 »
You want an inch...and/ or a shield as John mentioned!!
geralde
Re: Header install
Post by geralde »
Well I don't want to be a Comet literally, so I will reroute the fuel line. Thanks
Re: Header install
Post by Rocket989 »
Sorry was in a hurry this morning - inch minimum...more here is obviously better!!! :mrgreen: :lol:
Re: Header install
DOES anyone know where I might find a set of headers(long tube) for a 64 comet that will have a 351w and a top loader transmission in it??? drug my 64 pro street out of the weeds yesterday,,,thinking about getting back to work on it,as soon as raceing season shuts down in a few more wks...am going with M2 front end ,so there will be no shock towers,,,thanks POP
