pedal assembly
pedal assembly
is 64 falcon pedal assembly the same as a 64 comet and if so is a 65 fairlane the same as a 65 comet??
Re: pedal assembly
64-65 Falcon and Comet are the same. Dont know about the Fairlane.
Re: pedal assembly
Fairlane is different.
64 brake pedals had a small eccentric master cylinder push rod bolt and the master cylinder had a pressure activated brake light switch.
In 65 Ford moved the brake light switch to the pedal and it was mechanical. So the 65 has a large fixed master cylinder push rod pin on the pedal.
