Hello all,
I believe I have a bad headlight switch. Problem is that I lose my interior and tail lights intermittently. When I put slight upward pressure on the switch assembly under the dash everything works great. My question is that it looks like the small fuse box is part of or attached to the headlight switch. Anyone have some advice to share in replacing this switch? Is the fuse box attached? My replacement switch does not have fuse box attached.
1964 Mercury Comet Caliente
Thanks
Burt
64 headlight switch replacement
Re: 64 headlight switch replacement
Sound's like the wrong switch.
There is a spring loaded push button on the side of the switch. Push it in and pull the knob and shaft out. Then you can unscrew the bezel on the front and remove the switch. There is a tool but I'm sure I can speak for a lot of us that have used needle nose plier's.
My 62 did that and I found a fuse rolled in aluminum foil. Replaced that and as far as I know it is still working.
Remove the switch and check for a loose terminal or bad wire. It could be that the lights you are having issues with share the same fuse. This sounds like a fire waiting to happen.HOT260 wrote:Hello all,
Thanks
Burt
Thanks for the replies. I'll try to get it out Saturday or Sunday and see if it matches my replacement.
Burt
Burt
Either loose terminals where the fuse block plugs on or in the fuse block itself. While you are messing with it might be a good time to install a new fuse block in a more accessible location and just connect it to the old fuse block. Would make future access so much easier.
