Hey Guys,
i have a 64 comet and of the 4 individual brake lights one of the 2 on the drivers side stays bright all the time when the lights are on even when the brakes are not applied any ideas how to fix this?......Thanks
Brake lights
Re: Brake lights
Likely an issue in the socket with the pigtail wires contacting each other.
Re: Brake lights
Thanks I appreciate it I'll take a look at that
Re: Brake lights
Also double check the light bulb. Should be dual filament. One is dim for running lights and the other bright for brake light and signal flasher.
I had a Chinese bulb stay bright for some reason. Also the little contacts inside the socket get smashed and act funny too.
Good luck and let us know what you find.
Edit- one more thing. If you don't find anything at the light bulb/socket you may have to take a look at the turn signal switch inside the steering column.
Re: Brake lights
Great thanks for the info ill start messing around with it and hopefully one of those things will fix it
