stock steering wheel size
Can someone do me a favour and please measure the diameter and depth for the stock steering wheel.
My car came with a flat grant one on stock column and I want to start thinking of interior stuff like seat position and such as I am changing to buckets with ididit tilt so I will probably drop 1 inch off of the diameter It will be a resto mod so I will be looking for a more modern wheel with original styling ..I just need a baseline to start .
If you have a pic of your wheel and your set up that would be cool ,we could have a steering wheel thread
Re: stock steering wheel size
stock is 16x6.mine is about 14.5. I took about 1.5 out of mine, of diameter. & made the ring a bit fatter. with ps & some steering mods it has more of a modern feel than it did. I added about 1.5 inches to my column &moved the shifter back about 6'' or more & moved the seat back about 3''. It all fits me now!
you made a new ring for the stock one?
Do tell how you went about that,i like the beafier look and feel
It's the same ring. I cut it off of the 2 spokes, cut out about 5'' from the top then welded it back together. It wanted to egg shape when I pulled the ends together with ratchet straps so I put more straps from top to bottom to make it more round shaped to weld it. & after welding it was still out of round so I put it on a block of wood & hit it with a BFH. then I slipped it on the steering column & box which was off the car ,clamped it upright, used a dial indicator to see where the high spots were, & beat it into submission. here it is with the dial indicator set up, before I welded it back on the spokes. I had a little concaved groove on the spokes to hold it while I would check it, then I could just pop it off & beat it.
after all the welding & grinding I used PC-7 epoxy to fill in the gaps. because the s wheel was so ragged on the top front that I put epoxy all over that part. Then I sanded it down when it dried . Every coat of epoxy meant more sanding & it was getting better each one but it was getting old fast so I would get the big ugly knocked down then lay it down for a while, sometimes months!
here is a comparison pic;
One thing that led me to make it fatter was so I didnt have to sand out ,,,make the finger grooves. this pic I had about half of it fat & still has grooves on the other side. everytime I would try to make the grooves it would look like crap so I just filled them all in.
It was a tedious process that I did a little at a time which helped the monotony, but it was still a lot of sanding! I think Ratical made his smaller by using a donor ring from something more modern, which would be a lot easier to do.
DON'T KNOW WHY YOU 'D WANT TO MAKE ONE SMALLER OR LARGER,,,MINE ON MY 64 IS PERFECT ,JMO
dont know why you gotta holler! but there are a couple reasons , my hand was hitting the window when I turned the wheel & to give it a more modern feel. but the main reason; I WANTED TO!!!popscomet wrote:DON'T KNOW WHY YOU 'D WANT TO MAKE ONE SMALLER OR LARGER,,,MINE ON MY 64 IS PERFECT ,JMO
if I don't holler..you won't pay attention but you gave the answer I expectedpoboyjo65 wrote:dont know why you gotta holler! but there are a couple reasons , my hand was hitting the window when I turned the wheel & to give it a more modern feel. but the main reason; I WANTED TO!!!popscomet wrote:DON'T KNOW WHY YOU 'D WANT TO MAKE ONE SMALLER OR LARGER,,,MINE ON MY 64 IS PERFECT ,JMO
That's the most radical mod' ive ever seen anyone do to a wheel. You did a good job.
Yes ,i agree.that was a lot of work and a challenge ..great job thanks
I agree withRon and King. That steering wheel is above and beyond!
Thanks guys. Like a woman knitting a sweater, I would do a little here & there,when I felt like it, as I rebuilt the car. so it wasn't too bad. Yes it was a challenge! but I have another challenge in mind: making a leather cover for it but in four separate sections, so the chrome bands still show. But I think I need to find help on the sewing part.
