65 back panel picture request
The Transplanter
Post by The Transplanter »
Do any of you guys have a picture of the back panel on your 65' with the bumper removed that you could post up for us ?
I knew mine had a previous bad repair from old collision damage, so I have just removed the rear bumper and chipped out all the old bondo so I can see whats going on :roll:
Would I be correct in presuming that the panel should be dead straight where the arrow is in the pic below?
Re: 65 back panel picture request
Check Arkansas Comet's post here maybe you can see what you need.
viewtopic.php?t=14098#p78354
The Transplanter
Thanks Mike
Looks like he had a similar problem to myself. It would be good to see a pic of an undamaged one if possible 8)
Couple pictures of mine. My Car was never hit or damaged, I did move the openings for the bumper mounts in tho.
Pretty sure it is straight across, may even have just a little bit of a outward/rearward bow. Can check the next day or so when I go to my shop if you would like.
Thought I had a picture with a straight edge across it, couldn't find it but found these if they help.
The Transplanter
That's great Lou 8) That looks pretty straight to me in those pics, thanks very much :)
Looks like I have some work to do :D
Cheers Al
