AOD conversion
AOD conversion
Hello. Lost all forward gears in 65 Mercury Comet with C-4 transmission. Considering converting to automatic overdrive transmission. Like to know if conversion kit for a mustang will work for my comet or if there is a kit that is just for the comet. Thank you.
Re: AOD conversion
Is Current C4 5 Bolt Bell Housing or 6 Bolt Bell Housing.
Re: AOD conversion
Soon as this storm is over with I will get under it and check. Probably on Sunday. Thanks.
Re: AOD conversion
I have a n AOD in my 65 404. Used Lokar floor shifter and works great.Only had to fab the rear member. Do yourself a favor and use the new Lokar TV cable and brackets. Also go online to Monster Transmissions and watch the videos on how to set up. They used a 64 comet as a demo....Good Luck....Ron
Re: AOD conversion
Barry. I finally checked it and it has a 6 bolt bell housing and a in case dip stick housing. Thanks.
Re: AOD conversion
FYI - Falconparts.com sells a crossmember that'll fit the AOD:
https://www.falconparts.com/ford-falcon ... 4p1148.htm
Re: AOD conversion
I have an AOD behind my 289. With my 3.50 gears in the back I cruise at 2200 rpm at 65 mph.
I needed to massage the tunnel with a BFH and trim the support to get mine to fit.
Well worth the effort.
G
G
George
1965 Comet 202
1965 Comet 202
