Best Master Cylinder for NON Disc
kellycj
Post by kellycj »
Going to replace the "mason jar" cylinder with a dual reservoir (stock one died), but will still be running the stock front/rear manual drums. May switch over to disc in the future, but right now I need a MC to get the brakes up and running. All of my searches lead to disc brake swapped set-ups; what is the best manual drum/drum MC? 67 Mustang or Fairlane? Thanks.
Re: Best Master Cylinder for NON Disc
If your car is a factory V8 any pre ‘68 V8 drum/drum dual master will work. You may want to install a residual check valve in the system, then when you install the front discs in the future you can change the valve to a pressure that is compatible with the discs.
https://www.freeasestudyguides.com/resi ... valve.html
Updating the brake lines is a good thought, over time the flexible lines can deteriorate from the inside out causing the inner liner to collapse which may not be visibly looking at the line.
Do not cut corners on Brakes or steering they are the two most important functions of any vehicle.
kellycj
Post by kellycj »
Thanks. So on a drum-drum, would I need a proportioning valve with the dual reservoir cylinder? This should be pretty simple for me, but for some reason I'm scratching my head a little. So it sounds like it might be wise to get a disc-drum cylinder, and install the check valve in the rear (front brake) exit port, then just remove it if/when I go to disc? Appreciate the help.
If you use a disc/drum master you’ll definitely need a proportioning valve!
tweaked
Post by tweaked »
I used the portioning valve out of a Granada/Monarch. I have 10 inch discs from a ranger. Non power set up.
Roger
65 comet 7.61@96mph 1/8
Tweaked65 on instagram
https://youtu.be/JCVwEitXSi4
bmmaurer
Post by bmmaurer »
I Put this system on my '63 Comet. Same set-up for a '64. It is a dual MC with a power booster that WILL fit in the cramp area. It is advertised as Disc/Drum. I put a check valve in the front side as recommended. NO proportioning valve was needed. Works perfect. Rework / Reroute of the lines and a few tees and it's done. The firewall "nutplates" will be knocked off and the MC stud bolts will fit with no issues. Page 89 of the ABS catalog. Part Number 9782 PB2.
http://abspowerbrake.com/maincatalog_frameset012.html
Any Questions, let me know. Go dual MC AND power !
Here it is installed...
Comet Bruce
kellycj
Post by kellycj »
So yours is a drum/drum? Where do you get the check valves for the disc/drum master cylinders?
CSRP will likely sell you one. He’s uses a slick bracket that mounts it underneath the master. Honestly, I’d just get a ‘67 ‘Stang MC for 4-wheel drums & change it later if you go to disc. With a disc/drum master you’ll also (most likely) have to run an in-line residual valve (at least one). The ‘Stang MC will pretty much drop right in with a minimal re-do of the brake lines.
If you want to keep your hydraulic brake light switch instead of converting to electric, you can use one of these:
https://www.speedwaymotors.com/3-8-In-2 ... EkEALw_wcB
ETA - For any tight bends I’d use the PolyArmor brake line(s). The NiCopp stuff is great & bends easy but because of that I’ve found it kinks much easier also.
kellycj
Post by kellycj »
Rocket989 wrote:CSRP will likely sell you one. He’s uses a slick bracket that mounts it underneath the master. Honestly, I’d just get a ‘67 ‘Stang MC for 4-wheel drums & change it later if you go to disc. With a disc/drum master you’ll also (most likely) have to run an in-line residual valve (at least one). The ‘Stang MC will pretty much drop right in with a minimal re-do of the brake lines.
Thanks. The Mustang drum/drum master is the way I've been leaning; not sure if I'll ever get to the disc swap, so it's probably the best route. Not like they're several hundred dollars anyway, so an upgrade later won't break me.
bmmaurer
Post by bmmaurer »
kellycj wrote:So yours is a drum/drum? Where do you get the check valves for the disc/drum master cylinders?
rum
Yes Drum/Drum. Check valves are available at most parts stores.
Do it once right and be done!
Comet Bruce
