'65 Wiring Harness at Firewall (Inside)
kevinshi
Post by kevinshi »
Hey folks -
From the cab side of the firewall does the wiring harness simply unplug? I have tried pulling on it (lightly) a bit and it not budging. Before I start really giving it a strong pull would be nice to know exactly what type of connection I am dealing with...
(I need to remove my entire harness from the car - I have it all balled up and free... now I just need to get it disconnected from the firewall...)
kevin
Thanks,
kevin
1965 Caliente Convertible
5H25A525287 (76DM6204L5416)
Re: '65 Wiring Harness at Firewall (Inside)
Look under the hood, I think you unplug from outside the firewall, there are two plugs up next to the master cylinder.
lavron wrote:Look under the hood, I think you unplug from outside the firewall, there are two plugs up next to the master cylinder.
Mike is right. it just pulls off from the engine bay. you may have to wiggle it back & forth. then to get the cab side of the plugs off the firewall >>you must work from the engine bay side as well. there are some barbs that hold the plugs to the firewall. use a screw driver to push in the barbs so you can push the plug in. I think there are 4 barbs per plug.
on the plus side,,, putting it back on is a breeze! :lol:
kevinshi
Post by kevinshi »
Dang I'm struggling with those barbs. I think I've already broken at least one off... arg...
Thanks,
kevin
don't try to pri out,,,try to push them against the plug and pull at the same time,,you ain't the 1st to do this and you ain't gonna be the last...don't give up,,,I use a small pocket screwdriver,,but that's just me.....POP
kevinshi
Post by kevinshi »
I got them but I think busted off about half of the Barb's in the process. Geesh. Thanks for the encouragement in any case!
Thanks,
kevin
COOL !! ol pop knew you would get it,,never give up !!! :wink: 8) pop
