Sub frame connectors
french2
Post by french2 »
Have any of you guys added sub frame connectors to a 64 Caliente? All I have found so far are Global West Suspensions Part # 916, but they can't say if it will fit the Comets. Application is for a Falcon or Ranchero. I can fab some up, but if there some available, I would rather go that route. Thanks.
vicegrip
Re: Sub frame connectors
Post by vicegrip »
Crites work OK. Wouldn't recommend them for all out racing
barrys65cyclone
Post by barrys65cyclone »
Kingspeedy2
Post by Kingspeedy2 »
There isn't much to the crites subframe connectors ,a straight section of tube notched to connect at the front section and a piece of 90 off of that to connect to the back.I assume you have a welder or access to one.If I had to do it again I would have thought more of doing it myself and just bought the tubing .I used some doubles at the front to have some meat to connect the crites to the front sub frame as the crites tubing is wider than the subframe and there is a gap
unfortunately I am away from home for 6 weeks so can't send pics.
I don't have any experience with any other brands
I looked for some 2 x 3 box channel and didn't come up with any, so I took 2 x 3 angle iron and made my own box welding them together. Then welded the box onto the bottom of the sub frame in back and up into the torque box in front. I did take a 1/4" plate and welded it across the new box frame and the original sub frame up front to tie it all in.
It's a little heavy duty but I installed a 4 link suspension that's tied into it. So all of the thrust of the rear axle is against the new sub frame.
tom
Here's some pics on how I did mine, also a pic on the next page.
Starts down about mid page.
http://www.cometcentral.com/forum/viewt ... 8&start=75
