Caliente hubcap different offsets F & R?
luc3ch
Post by luc3ch »
A guy at the swap meet a few weeks ago was telling me the stock Caliente hubcaps had a bigger offset on the front ones to clear the bearing grease cap.
Is this true? Thinking about getting hubcaps off Fleabay and don't want an unusable set.
1964 Comet Caliente, 302, upgraded to Toploader, front disk brakes ready for 2021 season after the snow melts!
Re: Caliente hubcap different offsets F & R?
Dud you fall for it?
I got hub caps
luc3ch wrote:A guy at the swap meet a few weeks ago was telling me the stock Caliente hubcaps had a bigger offset on the front ones to clear the bearing grease cap.
He may be thinking of the Cyclone faux chrome wheel hub caps. They are specific front and rear, all others are the same no matter which corner of the car they are installed on.
A/FX wrote: He may be thinking of the Cyclone faux chrome wheel hub caps. They are specific front and rear, all others are the same no matter which corner of the car they are installed on.
Well I learned something today, Thanks for sharing
luc3ch
Post by luc3ch »
Thanks, I can order the wire style ones as a set then.
