1964 Mercury Comet Caliente Build
darryl27529
Re: 1964 Mercury Comet Caliente Build
Post by darryl27529 »
Thanks everyone for the input. I am waiting on some 12 AN fittings and a bracket that fits 351c with an electric water pump. Hope it works. Planning to test fit the motor soon and will add some pics. Darryl
darryl27529 wrote:
Mon Sep 12, 2022 8:20 pm
''Planning to test fit the motor soon and will add some pics.'' Darryl
Good idea. like Fred mentioned those pulleys are way out there for a comet. you need to see where that motor wants to sit. especially with an MII . these comets are tight front to back with motor in stock position.
be good to check header fitment too.
darryl27529
Got a new Cleveland style alternator bracket in this afternoon and i am thinking that it will work. There is a little clearance for the water fitting on the head so that was good news.
Now the trick is to get this…
To fit in here…
I am thinking a little cutting will be needed. I have been measuring and it’s gonna be a snug fit. Hope to have more soon. Darryl
Happy to read your test fitting.
Hope those upper control arm mounts
dont slip,,,. Is this a common setup for uppers? I only have experience with shim stuff.
darryl27529 wrote:
Mon Aug 08, 2022 12:05 pm
Looking for suggestions for a harness bar/ roll bar. Should I buy a kit or take it to a fab shop? What did you do for a roll bar?
Just saw this post-
When I was considering my cage I called a couple local shops didn't like their prices or wait times so I bought a pre-bent kit from Rhodes Race Cars https://www.rhodesracecars.com/60-70-FA ... _2888.html
I got the 1 5/8” DOM SCCA kit. The fit was just about perfect. I had to tweak the passenger side A-pillar bar for my application but other than that its a great fitting cage.
I had to learn how to make prettier welds and to notch tubing but it was worth it in the end.
They have a few different style roll bars that might fit your needs.
darryl27529 wrote:
Mon Sep 19, 2022 10:47 pm
Looking good, D 👍
It will fit between the fender wells but you may have to build headers for this application.
Mine are hammered a little for steering shaft clearance on 5L engine w/ R&P. Don't know about taller deck height & Cleveland head.
darryl27529
Been working on the Comet past couple of nights. I pushed it out of the garage. Even without a hood, engine, lights, dang she looks fast just sitting there.
Pushed out of the garage.jpg (194.82 KiB) Viewed 1305 times
Started work on the front fenders. I am using the Eastwood Low VOC epoxy primer. Having a few issues with the spray gun but the results came out pretty good. Gonna paint the inside of the fenders first (body color) as I think its good practice for me. Stay tuned.
Fenders in Epoxy Primer.jpg (210.22 KiB) Viewed 1305 times
Good on ya! Practicing getting to know your gun.
When I first started to spray I was told to use a 45 gal drum to practice on because it was important to keep the gun at 90° to the surface. To this day everytime I load a gun I think of that.
It has a good looking stance! :P
darryl27529
Anyone know a good source for bumper brackets front and rear for a 64? I have been looking and cant seem to find them.
They're available on EvilBay but they're going to be for a 'Cyclone' and overpriced.
Hang in there.
darryl27529
Started the test fit tonight. It’s gonna be a tight fit. The oil plan has one sump too many I think to clear the rack and pinion. The good news is that I could squeeze a sheet of paper between the water pump and the radiator. The header on the passenger side looks like it will fit. Driver side will be a challenge for sure. Thinking I need to brush up on some welding. More to come.
I'm running a stock front sump pan on my engine w/ power R&P steering, no issues. I'd prefer a larger sump but don't know which would fit the power rack due to hose clearance. My rack is mounted behind the engine mounts.
darryl27529
Thanks JT. I am going to pull the pan and modify it for clearance. Hope it works! Like you said it’s a process to get to the end result.
My buddy Greg came over yesterday after work to help sand and get ready for more primer. I used Eastwoods low VOC epoxy primer. It’s not perfect but looks to be a pretty good base for next layer of primer and paint. Making some progress.
Gonna be an awesome ride! Colour?
