My new 65 Caliente
Re: My new 65 Caliente
Car is looking good, welcome back
Nice find! It isn't the gears that are nodular,it's the case.If you would,could you post the casting number and the date code?
Thanks for setting me straight Vicegrip. I didn't think it was the gears but I have two guys that have been around 30 years longer than me telling me that it's the gears that are nodule. So I went on the net and looked it up, its the case!!
One of them owns the 9 inch so I'm going to keep my mouth shut until I can talk him out of it.
He tells me it is out of a 1/2 ton 4x4.
I'll be over there next week. I'll get the numbers off of it.
More later, Matt
More later, Matt
Yea goodfind! better iron with extra webs. it also has one of the stronger pinion housings!! Get that if you can.
I think Johno is right.It looks like it has the Daytona pinion support. If you rebuild it,it does have different bigger pinion bearings than a standard 9.
That N case is definately a good find. There is also the chance it might be a 31 spline rear end. Not that the 6 banger needs it, but once you switch to V8 power you should be set.
I think it has to be 31 spl. Don't think they ever had a 28spl in a 4x4 or in an ''n'' case, even for cars.loman wrote:That N case is definately a good find. There is also the chance it might be a 31 spline rear end. Not that the 6 banger needs it, but once you switch to V8 power you should be set.
Can you tell what the housing came out of?? I agree - nice find man!
Loner here is a useful link that tells about the N case & daytona support.
http://www.kevinstang.com/Ninecase.htm
A regular pinion support is thicker under the bolts,skinnier in between them, where the daytona is thick all around & like vicegrip said it has a bigger bearing. some pics of both in that link. I have one of the 9 1/2 / (9 3/8) chunks in a truck but they aren't strong as the nodular.
and if you ever want to put the bigger ring gear in a regular 9in housing ,,,,,just grind a notch at the top and it'll work like a clock......poboyjo65 wrote:Loner here is a useful link that tells about the N case & daytona support.
maybe there wasn't enuff notch at the top,,makes no any who how,,,you made it work!!! for some reason ..I want to say not all N cases were 31 spline,,,I just don't recall,,,so don't take what I say to the bank......
Yea I anit sure about the 31 part Pop,but seems like I read it somewhere. I have a housing gasket that came with a notch in top & bottom. I'd say you could cut the top enough to not need to cut the bottom just by looking at the gasket, it seems to be a bout a 1/4 on top & bottom. but when I put in that chunk I had to cut that gasket & didnt want it getting too narrow at either top or bottom.
