Engine swap
Re: Engine swap
Comatt wrote:
Thu Nov 03, 2022 10:09 pm
Joe, how much hp can you pull out of a 289?
I believe the Daytona 289’s made like 450hp at 8000rpm
Re: Engine swap
comethead wrote:
Mon Feb 27, 2023 3:14 am
Oh, 289s singin a 8G,, THAT WOULD BE A BEAUTIFUL SOUND!
Re: Engine swap
Mon Feb 27, 2023 11:09 am
Crank up the speakers, Fred :D
https://www.youtube.com/watch?v=_opXUF1zK0Y
Re: Engine swap
This is one of my all-time favorites. Not sure what engine he's running, but its beautiful to watch and listen to. Nice footwork, too.8)
https://www.goodwood.com/grr/race/histo ... bT7XeSxtus
Re: Engine swap
Mon Feb 27, 2023 9:21 pm
That looked like fun :D
Tom
Re: Engine swap
Those little Porsches didnt have a chance! :twisted:
Re: Engine swap
Mon Feb 27, 2023 1:32 pm
Beautiful!! That dude was barely under control! That’s racin’!!
JimsHot66
Re: Engine swap
Post by JimsHot66 »
That is cool! Sounds just like my car... :lol: :lol: :lol:
GasserMac
Re: Engine swap
Post by GasserMac »
My '65 has a 351w. The towers haven't been cut but it is tighter than a banjo string to change plugs. For all the headache and hassle you're better off to stay in the 289/302 family. That said, I'm putting a 351c where the W currently resides so I'm looking at a whole new bunch of problems...Should you go with a 351w, check out Tubular Automotive for headers to fit. Still gonna be tight but better.
The front may also sit a bit lower due to the added weight. A C4 trans will work without tunnel mods. Consider upping to a 9" rear. Radiator may need an upgrade,too...good luck brother...Mac
Re: Engine swap
Wow! just watched that video. Hard to even imagine those little porsche's are going all out, with the ease in which he passes :)
kellycj
Re: Engine swap
Post by kellycj »
GasserMac wrote:
Sun Apr 02, 2023 3:07 pm
You're a magician to get a 351W in there; a Cleveland even more so. My 302-based stroker is extremely tight, and the headers had to be flogged on to get them to fit. As far as power, not sure what my 331 runs, but with a T5 swap it is a blast to drive, and FAR exceeds my early 65 that had a 289/C4. My biggest concern is it hooking up and turning the T5 into a grenade.
Re: Engine swap
I ran a cleveland in mine with the stock shock towers for 20 years before finally cutting my shock towers. It was really tight, I had a set of headers which had each pipe was individual and two crossed under the motor and into slip on collectors. It took all day to install, as many of the bolt could only be turned a quater turn at a time with some tiny ignition wrenches. As I got older I gave up and cut the shock towers back and now no issues.
kellycj
Re: Engine swap
Post by kellycj »
The heads wouldn't clear the towers in mine, without a doubt. Changing plugs in this one is tough, I couldn't imagine the big C heads.
Re: Engine swap
I had the same issue for years after I installed the Boss 302 in my Cyclone, special headers and a real chore to install them or change spark plugs.
This time around I sectioned the shock towers and was able to gain precious inches, maintenance is much easier now.
Re: Engine swap
Comatt hasn't signed in for 4 months or so. I wonder if all your input has fallen on the floor?
Are you still around Comatt?
If so have you made any decisions?
