Drive Train Swap
rhtopdown
Drive Train Swap
Post by rhtopdown »
Have a 64 convertible Comet. Has 289, Want a newer model fuel injected engine, auto trans (floor shift) and matching rear end. Have heard newer mustang swaps easy. But do not know which years would work or even if I can do this. Help Please
CALIFORNIA CALIENTE
Re: Drive Train Swap
Post by CALIFORNIA CALIENTE »
Any 5.0[302cu.in.] engine will fit as they are the same,physically,as your old 289.Modern Transmission,as in Automatic would be the AOD or AODE,try to get the trans with the engine along with all the wiring and accessories!! ROY.
Real Racecars have 3 pedals
gmsnowball
Post by gmsnowball »
Roy, will the AOD require a modification to the tunnel, if so what is required?
Gary
Oklahoma Somewhere
Just Outside the Neutral Zone
64 Comet Calentie Convertible
CALIFORNIA CALIENTE
The AOD is a LARGE transmission,it will take some tunnel mods,header mods,and the floor brace needs to be either removed or severily trimmed.The biggest issue we found when doing one was the speedometer location and getting the tailshaft 'UP' in order to match the driveline angle of the original trans!If you do not match the driveline angle,you 'WILL' have vibration issues,this is from experience,not conjecture!!! ROY.
lowrider91
Post by lowrider91 »
Just bought a 63 S22 with that exact set up. Will be removing it soon to put a 289/toploader back in. Where are you located?
lowrider91
It's an 89 EFI 5.0 AOD w/B&M Quick Silver floor shifter. Leave an email. I can send pics and vid of the car running. Jim
rhtopdown
Post by rhtopdown »
sorry took so long hope you can send me pics/vid texasrh@sbcglobal.net thanks
rhtopdown wrote:Have a 64 convertible Comet. Has 289, Want a newer model fuel injected engine, auto trans (floor shift) and matching rear end. Have heard newer mustang swaps easy. But do not know which years would work or even if I can do this. Help Please
So will you be selling the 289 setup? If so, what trans do you have now? 4 speed?
rhtopdown
Post by rhtopdown »
It has a 302 not sure which year. C4 transmission
sursmilie64
Post by sursmilie64 »
I put an explorer 8.8 rear in my 63 fairlane. 31 spline, 373 gear , limited slip, n disc brakes. Just cut drivers side down to passenger side lenth and install a passenger side axle in. will work with overdrive, but more gear is better.
