Hey guys! So here's a link to the original build thread for the car: http://www.cometcentral.com/forum/viewt ... 4&start=15
The short version is that the car has a 2.3L from a '93 Ford Ranger. I drove it 3 1/2 hours home, and it got 27 mpg.
Here's a link to some pictures: https://drive.google.com/folderview?id= ... sp=sharing
I'm sure you'll notice the terrible weatherstripping. Well...I have to drive this daily, and it's cold. So it's a bandaid solution. I'll fix it properly once the weather gets nicer. But that's why the driver side door isn't closed all the way. It only closes completely if I slam it, but if I slam it the window pops off the track. So that's another thing to fix.
When I bought the car, the shifter was broken. I drove it home with a clamp holding it in place. The next day a metalworker friend of mine fabbed up the new shifter and welded it into place.
Anyway, I'm looking forward to messing with this car. I need a back seat, and I'd like to polish up the interior a little bit. I'd also like to add a little bit of audio. One day, maybe a swap to the 2.3L turbo motor.
Build Thread - '62 Comet
Re: Build Thread - '62 Comet
At least with it running and driving you will be able to make the upgrade fixes as you go.
Looks good!
Keep in mind some later parts fit your car as well. 65-66 Mustang parts are cheap.
