steering column
steering column
Ok so I replaced the turn signal switch, I must say whoever designed this needs to be slapped... this has become a pain in the ass....Now the shift collar will not stay in place. It keeps popping off.... It also seems that something is missing. There are two 7/16 nuts that seem to not hold anything down. It also seems the innards of the column seem to shift to the right. So in order of removal, I removed the steering wheel, turn signal cam, turn signal switch, the piece that the switch, cam, and indicator screw into, and the column shift collar...I am stumped.
Re: steering column
Those 2 7/16 nuts hold the guts together. there shoulb be 2 bolts that slide up from under the collar with square heads that fit into recesses. Might need to locate a diagram
62 Comet 4dr Base...Current PROJECT...wife's car..intalling 200 6cyl and a T-5.
OTHER
2011 Victory Cross Country (M/C) always needs wash and wax
1997 Ford F150 4X4
OTHER
1997 Ford F150 4X4
Re: steering column
Question is what guts?
Re: steering column
Question is what guts?, and I have searched all over for a diagram
Re: steering column
ok I see where they go, but how in the hell do you get them in there to tighten up?
Re: steering column
Just barely start the nuts beforehand ,then slip it on .just the edge of the nut hangs on the hole. here is where you fish for the holes, when you get a bite snug each one up a little . get them all in place then snug them up evenly.
Re: steering column
Ok next dumb question.....I cant remember where the spring went....damn crs
Re: steering column
spring? damn crs big one?captian_napalm wrote:Ok next dumb question.....I cant remember where the spring went....damn crs
Re: steering column
small one. I know the big one goes under the horn ringpoboyjo65 wrote:spring? damn crs big one?captian_napalm wrote:Ok next dumb question.....I cant remember where the spring went....damn crs
Re: steering column
Little copper spring? Horn Brush?captian_napalm wrote:Ok next dumb question.....I cant remember where the spring went....damn crs
Re: steering column
Here Ya go...
Re: steering column
bmmaurer wrote:Here Ya go...
that helps..looks a bit different
thanx
Re: steering column
where did you find this?
Re: steering column
I have Part 1 and 2 of 1960-1964 Master Parts Catalog
Re: steering column
well i got it all back together and the new switch isnt working....rt signal works but no indicator...left does not work yet the indicator is steady.... not blinking....replaced bulb....i have parking lights......any thoughts?
