302 engine
hotrodron
302 engine
Post by hotrodron »
Hey guys, I have problem ID ing my engine. I bought my 65 comet approx 4 months ago . the car runs drives great, just want to do improvements Etc. so Its mine.I cannot find any cast or id #'s anywhere. nothing by distributor or behind the starter. according to past owner its a 96 302 Ford crate motor. It has a AOD tranny. Any info ? is it a roller motor? how can I tell? Thanks. Ron
Loner
Re: 302 engine
Post by Loner »
Nothing under the starter??
Matt
redhotcomet
Re: 302 engine
Post by redhotcomet »
Pull a valve cover. There might be an id number in there somewhere. Post some pictures if you can. The only surefire way I know to determine whether its a roller cam engine is to pull the intake manifold.
bmmaurer
Re: 302 engine
Post by bmmaurer »
Under starter...
hotrodron
Re: 302 engine
Post by hotrodron »
Thanks for the reply! there is nothing under around starter, which I replaced, just stippled? casting as on rest of block This 302 is crate motor w/ aluminum SVO heads. I guess I'll have to pull the intake. Any other ideas? Thanks....Ron
Lip Ripper
Re: 302 engine
Post by Lip Ripper »
If you have a bore scope type of camera you could pull the distributer and look through that opening.
And the numbers won't be cast, they'll be stamped.
Stacey
bmmaurer
Re: 302 engine
Post by bmmaurer »
Lip Ripper wrote:If you have a bore scope type of camera you could pull the distributer and look through that opening.
Stacey
...and see WHAT ?
redhotcomet
Re: 302 engine
If its a roller cam you'll either see the factory type dog bone lifter retainers or link bar style lifters. If not you'll see regular old flat tappet lifters tops.
Re: 302 engine
Post by Rocket989 »
IIRC the late-later block markings were largely on the driver side...may be the same for FRPP crate engines.
hotrodron
Re: 302 engine
Post by hotrodron »
thanks to all for your help. going to pull intake...Ron
