8" weird problem
8" weird problem
Postby Boatmangc » Thu Aug 17, 2017 5:01 pm
I bought a 3:80 third member from TJ on Ebay.
Swapped ot out no problem, while the axles were oit i put on adapters for rear discs.
Pit it all together then realized the wheel studs were way too short.
Pulled the axles again, changed axle seals, changed studs, put it back together. Except the DS axle won't go all the way back in, it engages the splines in the 3rd member about 5/8" the oiter bearing goes into the axle housing less than 1/4". Then it stops like I'm hitting something solid.
Confused....
1967 Caliente Hardtop Small Block
Factory A/C
Factory Front discs
Factory AM/FM
Boatmangc
Re: 8" weird problem
Postby poboyjo65 » Thu Aug 17, 2017 5:27 pm
Maybe they aren't going into the splines of the third member. Maybe wiggle & push a bit harder while rotating the axle slightly :?
347, 4sp, 9''
JOHNO
Postby Boatmangc » Thu Aug 17, 2017 6:52 pm
Tried a few tricks, poured some gin.
Tomorrows another day
Factory A/C
Factory Front discs
Factory AM/FM
Boatmangc
Postby Comechero65 » Thu Aug 17, 2017 6:59 pm
Did you get the new seal pressed in far enough?
Comechero65
Postby comethead » Thu Aug 17, 2017 8:11 pm
Is it a limited slip unit?
I seem to remember there needs to be spline alignment when you assemble those. I know you had it together already- but when the axle enters the diff can you turn it and push to see if it engages and slides in more?
Might be a good time to test TJs customer service skills :D
Image<click
1965 Caliente HT
289/4 speed
Postby Comechero65 » Thu Aug 17, 2017 11:16 pm
If you have an ls you have to get both sets of teeth aligned inside the clutch assm. Of course I don't know how they could have moved on you if you never had that part apart. Try hooking the first set of splines and rotate some and maybe then it may slip the rest of the way ok.
A non ls should go right in i would think.
I just realised Joe had said basically the same thing.
Comechero65
Postby Boatmangc » Tue Aug 22, 2017 10:17 am
You guys were right. TJ confirmed it.
Locked down Passenger axle with a pry bar
turned DS a little while pushing in. Bam! right in.
Factory A/C
Factory Front discs
Factory AM/FM
Boatmangc
Return to Drivetrain
Users browsing this forum: Bing [Bot] and 2 guests
