transmission jacks
transmission jacks
I'm swapping c-6 trans in the race car. I hurt my back a bit fighting with installing it this weekend using a floor jack. I have to take it back out and looking to make things easier.Does anyone have any recommendations for tranny jacks? Harbor Freight, Northern Tool or anyone else?
Re: transmission jacks
HF used to have a saddle/adapter that worked with a floor jack but I don't see it on their website. If you can find something like that it would would be cheaper than a dedicated transmission jack.
I bought one of those HF jacks many ,many yrs ago that has a snout that fits a floor jack,,,but as I've had a lift more yrs then I can recall,,,,,,,what I did was weld a 2 in nipple on the top of the mast of my cherry picker,,I put that adapter on that nipple and use it to lift trans and rear ends in place,,I just have to lift them up on the adapter ,,,have done it this way for yrs...but like I said..ol pop has a lift,,,but the same adapter works off a floor jack..........in my younger days ,I wish I had a dollar for all the AT's I have put in by hand,,they are sure heavy,,,,but I would brag on how strong my little brother was and could always count on him to help me....BLESS HIS HEART,,,,brag on him alittle and he'd lift the tire off the ground,,,,,,I sure love that 66 yro old man today
I have the China Freight model. It works but there is a lot of slop in the scissors. I've put 2 trannys in/out with it in the 7 years I've owned it so I deal with it. It works well for changing VW dune buggy engines. I've used it a lot for that.
Stacey
Stacey
Same here...the HF one works well enough. The strap is about unusable in tight tunnels like our Comets (the rachet buckle is huge) but a couple giant zip ties works fine!
whom ever came up with those zip ties ,flat had a good idea.....those things are used on lots of things,,Rocket989 wrote:Same here...the HF one works well enough. The strap is about unusable in tight tunnels like our Comets (the rachet buckle is huge) but a couple giant zip ties works fine!
LOL,, I used them on my Falcon stock car to hold the bottom of the front fender in place.popscomet wrote:whom ever came up with those zip ties ,flat had a good idea.....those things are used on lots of things,,Rocket989 wrote:Same here...the HF one works well enough. The strap is about unusable in tight tunnels like our Comets (the rachet buckle is huge) but a couple giant zip ties works fine!
If the fender got pushed into the tire the tie broke before the tire was damaged
THEY help hold rad's and brake lines in place.. on these race cars we have...just last week I used them to hold down a tarp on a trailer to keep stuff from blowing out while going down the hwy....SASSY wrote:LOL,, I used them on my Falcon stock car to hold the bottom of the front fender in place.popscomet wrote:whom ever came up with those zip ties ,flat had a good idea.....those things are used on lots of things,,Rocket989 wrote:Same here...the HF one works well enough. The strap is about unusable in tight tunnels like our Comets (the rachet buckle is huge) but a couple giant zip ties works fine!
Invented in 1958 by an electrical company for aircraft wiring harnesses.popscomet wrote:whom ever came up with those zip ties ,flat had a good idea.....those things are used on lots of things,,Rocket989 wrote:Same here...the HF one works well enough. The strap is about unusable in tight tunnels like our Comets (the rachet buckle is huge) but a couple giant zip ties works fine!
Check it out under "History" https://en.m.wikipedia.org/wiki/Cable_tie
I stopped by Harbor Freight and bought the 800 lb tranny jack. I think it should work. I'll have to jack the car up higher in order to get the jack with the trans on it underneath the car. Once my back stops hurting I'll double check my converter to flexplate clearance and pull the trans back out and make the necessary alterations.
Have to think on that statement for a whileloman wrote:bought the 800 lb tranny jack
Used the jack last night and removed the C6 again. I'm going to have a bit of machine work done to the converter, and hopefully back in car later this week.
yea it's a black & decker!Jims65cyclone wrote:Didn't know you had a CNC milling machine, John.
