the right carb cfm for 260
Postby 62Cometman » Wed Nov 08, 2017 12:33 pm
So ive been wanting to upgrade the 260 i recently purchased to try and squeeze just a little more HP out of the motor i ran across bmmaurer's post stating he used a edelbrock cam intake and a 465cfm holley carb but from the calculations ive seen these motors with 85% VE only need 350 cfm and only hit the 450 cfm mark at 100% VE so is he jsut over carbing the motor for its needs or would is that just general practice this motor is goning to be no where near 100% VE so could i get away with like a 350cfm 2 barrel or would a 390 cfm on a 4 barrel intake work better? Idk, maybe im just over thinking things :roll:
62Cometman
Re: the right carb cfm for 260
Postby Rocket989 » Wed Nov 08, 2017 12:51 pm
A 450-500cfm 4V carb will work well. I've also used the 390cfm Holley but prefer the slightly larger carbs - they run better.
Holley has a few options...their 465cfm traditional carb (I believe they have versions with hot air or electric choke options) as well as the 80570 Street Avenger (the polished zinc version) which is marketed as a 570cfm carb but actually flows 465. I used the latter on my mildly modified (268H cam & Edelbrock intake) and it ran great.
Summit has released a 500cfm version of their house-brand carb which is an evolution of the original Autolite 4100's (and Holley 4010/4011's) and appears to be a good value with annular boosters, etc.
Or you can find a decent 1.08 Autolite and rebuild it! :D :lol: :lol:
Any of the above should be GTG.
Postby Lip Ripper » Wed Nov 08, 2017 1:47 pm
More fuel to make up for the inefficiency of the cylinder heads.
Lip Ripper
Postby popscomet » Thu Nov 09, 2017 1:28 am
OL POP has a 77 bronco with a bone stock 302,with a CI INTAKE AND A 390 HOLLY, this thing runs like a singer sewing machine ans gets super doper M PG,,it has a AT trans and a 3.50 gear....works like a clock!
Postby bmmaurer » Thu Nov 09, 2017 6:49 am
I'll post my reply again. Click on the links and read what Shelby and the others designed for the 260 V-8. Many opinions here but I would stick with Shelby's design and research.
Comet Bruce
Hi, Here's the set-up that will make you smile... Guaranteed!
I visited my Father-in-law over Christmas and he showed me his new "toy". He had purchased a '65 Sunbeam Tiger. FYI a Sunbeam Tiger is a British sports car with a FORD 260 and then a 289 V-8 stuffed in it. The engine package was designed with help from Shelby. The car ran so much better than my Edelbrock 500 cfm Performer on top of a Performer 289 intake with a Performer cam.
What I'm saying is forget the Edelbrock carb idea, Go with a Holley 0-1848-1 vaccum secondary 465cfm 4bbl carb with the Edelbrock Performer 289 intake and a Edelbrock Performer cam set-up.
[b]Why do I say this? Shelby got together in the mid '60s to design an "super induction" system for the Sunbeam Tiger call the LAT 1 package. It consisted of a Holley 0-1848-1 465 cfm 4bbl carb, the Edelbrock 4FB intake manifold and a mild cam. Here is the info on the induction package...
[/b]
http://www.team.net/html/tigers/1998-01/msg00084.html
Why this set-up? I just finished putting this carb on my 260 with a Performer Intake and a Performer cam and the car runs $^*(%^^%(%$ Perfect. SO much better thatn the 500 cfm Edelbrock Performer carb with all their screwed up tune up spring and jet set. Out of the box this thing is perfect. Here's the carb info from Holley. I got one open box for $320.00 from Summit (sharksmotorsports) on ebay.
https://www.holley.com/products/fuel_sy ... s/0-1848-1
Since Carrol Shelby designed this induction system for the 260/289 V-8's, I would trust his expertise over all our buds here. (and they're good)
If you still want to go with a Edelbrock, I'll sell you the one I just took off with the tune up kit. I would stay away from the finicky, rich running Edelbrock.
Here's Some pics...
bmmaurer
Postby redhotcomet » Thu Nov 09, 2017 6:51 am
I have a Holley Street Avenger 570 (465 cfm apparently) on my 302. Runs great.
redhotcomet
Postby bmmaurer » Thu Nov 09, 2017 6:51 am
bmmaurer
Postby 62Cometman » Thu Nov 09, 2017 10:46 am
Quick question for you bmmaurer the cam is the Performer Plus 2122, or the Performer RPM 7122?
62Cometman
Postby robib » Thu Nov 09, 2017 6:49 pm
Having a 260 I have this combo: Comp Cams hyd. cam (one step above stock with .447 gross lift and 212* duration int. & exh.) and a 4BBL. Then a C4 and a 3:25 open rear.
The cam is so close to stock, that the idle is "just" slightly noticeable. When putting this engine together, I was thinking about an intake and found doing research that the aftermarket intakes show little if any difference from a stock Ford 4BBL intake. I then went with an 1.08 Autolite 4100 carburetor. I had used this cam, intake, carb combo in my 63 Comet with 289/302 engine and 4 speed. It ran excellent and I changed to tripower and solid lifter cam just because.
So I put the 260 in my 63 Rambler American (2520 lbs). I runs great and for fun took it to the strip and turned a 15.9. Not to shabby, considering stock muscle cars of the era turned low 15s. Had a pretty good stumble coming of the line. This is the only problem I had with this setup. Had the combo in the Comet with 4 speed, so no stumble. With the 260, an automatic is used. Found out the carb I am using is for a 390 and the accelerator pump portion puts out more gas. I have gotten around that and took it to the track again. This time that little engine came "on" and with an open rear, it just sat there and spun.
So the Ford parts (less the cam) work very well. If you chose to use a 4100, make sure it is for a 289. Remember, the 260 is a "little" engine and the vacuum signal needed to open any 4BBL vacuum secondaries will NOT be in the lower RPM range. I tried different control springs with results that were not good!!
robib
Postby comethead » Thu Nov 09, 2017 7:11 pm
Im using a 1.08” Autolite 4100 as well on my 289/4 speed car. It has a 3.40 rear gear and is fun to drive! I believe the 1.08” Autolite is 480cfm.
Here’s a list of Autolite carbs. Like stated above stick to the small block 1.08” (if you decide to run that carb)
http://www.mustangtek.com/4100/ford4100.html
1965 Caliente HT
289/4 speed
Postby bmmaurer » Tue Nov 14, 2017 7:07 am
62Cometman wrote:Quick question for you bmmaurer the cam is the Performer Plus 2122, or the Performer RPM 7122?
Performer 2122
Comet Bruce
bmmaurer
Users browsing this forum: No registered users and 0 guests
