Daughters 65 Comet
Re: Daughters 65 Comet
Maybe you could get one of those cheap clear fuel filters to install right before the carb. Then you could give it a quick glance every now and then and monitor how clean the system is once you reinstall everything.
It looks good in the picture.
It has to be better than my parts cars tank. It had all kinds of dirt,flakes ,mouse nest,& the center of a locking gas cap was my guess,some kind of lock with key hole. & bad rusty.
I cut open 2 different 65 comet tanks. the worst rust was on the top & sides of both. from condensation. the bottom looked pretty good in both,could have been cleaned up. so looking down in the hole isnt much of a clue of the condition. a borescope would be good way to inspect it, if you have access to one.
But if you've been driving it with no issues it is probably in pretty good shape. I used those clear filters ,never did have an issue but the filter would get lots of junk in it until I cleaned & coated the tank.
Thats a good idea I already have filters in place but not a clear one by the carb.loman wrote:Maybe you could get one of those cheap clear fuel filters to install right before the carb. Then you could give it a quick glance every now and then and monitor how clean the system is once you reinstall everything.
Thanks
Thanks for the reply it turned out ok but there are some pits in the mateallavron wrote:It looks good in the picture.
[quote="poboyjo65"]It has to be better than my parts cars tank. It had all kinds of dirt,flakes ,mouse nest,& the center of a locking gas cap was my guess,some kind of lock with key hole. & bad rusty.
Thanks for all the help and the pictures. I do have a borescope and looked in the tank after you suggested it. There is some rust and slight pitting in the areas you told me about. However it is a little better then expected. I think we are going to eventually need a new tank. However for now I am just hoping to use your sender and this tank because the money is tight. It did not leak before so maybe it will be ok for a while.
Thanks again.
Thanks again.
Poboyjoe65
I got your sending unit in the mail and I wanna thank you very much. I bent the float and I think it will read right now. It was only going to about 3/4 before I bent it. Thanks again it is greatly appreciated.
Sorry it took so long to answer. I got all the tail lights from here https://www.parts123.com/parts123/yb.dl ... ~A140~A131Jims65cyclone wrote:Looks great! Where did you get your lenses?
Very nice people and great service. Melvins Classif Ford Parts
