Wanted: 64/65/66 Fender to Apron Brace (Both Sides)
If you need something, post it here
kevinshi
Post by kevinshi »
Updated: My earlier post (below) indicated that I need only the passenger side... well it turns out I need the drivers side as well...
I am seeking the passenger (RH) side "Front Fender to Front Fender Apron & Radiator Support Brace" as seen in the below picture (part number C4DZ-16A023-A).
I know this part appeared on the 64 Falcon as well as the 65 & 66 Comet. I suspect it also appeared on the sibling model/years (e.g. on all of the 64-66 Falcons and Comets).
I've been trolling ebay for quite some time hoping one of these might appear but I've not had any luck... I think I need to find a kind soul out there that has a parts car they are willing to scavenge for me... ;-)
Thanks in advance!
Thanks,
kevin
1965 Caliente Convertible
5H25A525287 (76DM6204L5416)
Re: Wanted: 64/65/66 Fender to Apron Brace (Passenger Side)
I may or may not have what you are looking for, I will look tomorrow, I just cut my core support out of the parts car and the right side had two braces attached to it, one has the end cut off one does not, I am afraid the cut one is what you need, if I have it it is yours.
kevinshi
Post by kevinshi »
Super!
Thanks,
kevin
I may have told you completely wrong I looked at this picture and it is on the drivers side, not sure why I thought it was the other one.
I think it is the correct brace but wrong side, do you know if they are the same? I can compare it with what is on my car and see.
As to your other post I have a sedan bench seat in the parts car, if any of it will work I can try and take it off for you, I will try and get a picture, I am sure it would need cleaned up.
kevinshi
Post by kevinshi »
Sadly they are NOT the same. :-(. Thanks for checking!
YES I am interested in sedan seat hardware!
Thanks,
kevin
I believe I have one. I will check ASAP.
kevinshi
Post by kevinshi »
comethead wrote:I believe I have one. I will check ASAP.
Super... fingers crossed...
Thanks,
kevin
Lige66
Re: Wanted: 64/65/66 Fender to Apron Brace (Both Sides)
Post by Lige66 »
Lige66 here.
The 1966 CAPRI FENDER APRON BEACES ARE THE SAME. COLLINS AUTO SAVAGE,COFFEEVILLE, IS.
HAS BOTH OF THEM.ALSO,TRY PURKEYS,,COFFEEVILLE.
Did you find one? I noticed I had one the other day but couldn't remember where or who said they needed it. not sure which side I had or if it is the correct one but I had tape on it & marked for where it goes, I just cant remember what it said. let me know if you still need it & I'll get pics .
I have the driver side,rusty but solid;
kevinshi
Post by kevinshi »
Many thanks but I did find a pair already - I appreciate the follow up!
Thanks,
kevin
