That's cool, the only reason I mention the Contour fans is everything I have read people say they are super powerful. Of course I am planning to change my core support to accommodate a wider radiator (fox body) because I can get a thinner (3/4" core), dual core, that should be near the size of the Contour fans and hopefully thin enough to fit in front of my water pump. I think at local JY there is some Grandas and LTDs maybe some T-Birds from the correct era and I was hoping to cut the center out of the core support from one of them and graft it in, then I could use the AC condenser from a fox body as well and just bolt it in.loman wrote:I was able to massage the Mazda Protege fans to fit on the radiator and clear the water pump and the water pump electric motor.
This is a list of cars I have to choose from (Lou gets credit for this find) for a core support, I have no idea if what I am talking about is even feasible I need to go look and measure first;
Ford Thunderbird 1980-1988 (200ci Straight 6-cylinder, 255ci V8, 302ci V8)
Ford LTD 1983-1986 (all motors)
Ford Granada 1975-1982 (Needs Hose Adapter)
Ford Granada 1981-1982 (all motors)
Ford Futura/Fairmont 1980-1983 (all motors including turbo models)
Ford Mustang 1979-1993 (all motors)
Lincoln Zephyr 1980-1983 (all motors)
Licoln Versailles 1977-1980 (Needs Hose Adapter)
Lincoln Continental 1982-1987 (all motors)
Lincoln Mark VII 1984-1992 (302 ci V8)
Mercury Marquis 1983 (140ci Straight 4-cylinder, 200ci straight 6-cylinder, 232ci V6)
Mercury Marquis 1984 (140ci Straight 4-cylinder, 232ci V6)
Mercury Marquis 1985 (140ci Straight 4-cylinder, 232ci V6, 323ci V8)
Mercury Marquis 1986 (140ci Straight 4-cylinder, 232ci V6)
Mercury Cougar/XR7 1980-1988 (all motors)
Mercury Capro 1980-1986 (all motors including turbo models)
Mercury Monarch 1975-1980 (Needs Hose Adapter)
