Alternative heater controls?
Posted: Fri Nov 26, 2021 7:20 pm
by SASSY
Just wondering. Im considering different ideas for a center console that comes up to the dash and each idea gets quashed by the heater controls and ashtray.
So my question, does anyone have any idea of a flat control panel that uses the same type cable controls that our system has? Of course I prefer a Ford product but open at this point.
Re: Alternative heater controls?
Posted: Fri Nov 26, 2021 7:41 pm
by Joe Travers
Have you looked into the Mustang or Cougar console, Fred? It comes up to the dash.
I'm trying to remember heater controls. I think they are vacuum actuated. Been too long ago.
Posted: Fri Nov 26, 2021 7:56 pm
by A/FX
You could loose the ash tray and relocate the controls to the console. The cables might have to be lengthened but that should not be a big deal. Or just relocate the controls to the inside of the glove box or mount them under the edge of the dashboard.
I removed my ash tray and used the tray face to mount the power window switches.
Posted: Fri Nov 26, 2021 9:37 pm
Might be easier to go back to the earlier 63 & back style with a separate knob for each cable. Most controls only have 2 cable levers.suppose you could make it work somehow. but singles seem simpler to mount,just drill a hole.
Posted: Fri Nov 26, 2021 11:07 pm
CHECK into seperate controls like on a 66 f100,,a knob for each use...just a thought pop
Posted: Sat Nov 27, 2021 1:06 am
by SASSY
Thanks guys ya been looking at images on Google including the 66 gen trks. I have seen anything that has the fresh air door either.
Posted: Sat Nov 27, 2021 1:42 am
ON my 66f100.the knob you pull for heat ,you also twist it for the blower,,,the heat valve is located in line on a heater hose....then a seperate knob for defroster.....pop
Posted: Thu Dec 02, 2021 1:01 pm
Fred you could figure out how to mount your comet controls behind a new front,,,face of the console. I made a bezel on a truck ,just cut the slots out for the levers;
Posted: Thu Dec 02, 2021 3:14 pm
by SASSY
Thanks Johno, haven't looked yet but pretty sure I have another heater control assembly to "hack" on so that is certainly a possibility!
