5.0 to go backwards?
I would like to know if and how a 1990ish 5.0 could be converted to points, condensor and carb?
Re: 5.0 to go backwards?
My engine is built on '91 5.0L roller block.
The 289 stuff bolts right up. Change the timing chain cover, water pump, oil pan, intake.
If its a roller cam 5.0 then just need to change the distributor gear. If you use the original points distributor cast iron gear it will chew up in a few hundred miles. Done that...
Will the rear sump pan fit the Comet? Worked on a stock 5.0L in a '65 2 years ago, already forgot!Boss/Cyclone wrote: ↑Tue Nov 22, 2022 11:25 amIf its a roller cam 5.0 then just need to change the distributor gear. If you use the original points distributor cast iron gear it will chew up in a few hundred miles. Done that...
In my 64 the steering components were at the back of the engine so it had a front sump pan. When I installed the mustang II suspension I had to change to a rear sump because the steering is under the front of the engine.
Yep,,,,,Joe Travers wrote: ↑Tue Nov 22, 2022 11:28 amWill the rear sump pan fit the Comet? Worked on a stock 5.0L in a '65 2 years ago, already forgot!Boss/Cyclone wrote: ↑Tue Nov 22, 2022 11:25 amIf its a roller cam 5.0 then just need to change the distributor gear. If you use the original points distributor cast iron gear it will chew up in a few hundred miles. Done that...
That oil pan is true hod rodding, whatever it takes. Love it.SASSY wrote: ↑Tue Nov 22, 2022 2:50 pmYep,,,,,Joe Travers wrote: ↑Tue Nov 22, 2022 11:28 amWill the rear sump pan fit the Comet? Worked on a stock 5.0L in a '65 2 years ago, already forgot!Boss/Cyclone wrote: ↑Tue Nov 22, 2022 11:25 amIf its a roller cam 5.0 then just need to change the distributor gear. If you use the original points distributor cast iron gear it will chew up in a few hundred miles. Done that...
Lol thanks Boss!
Necessity,, mother of invention.
Like alot of my stuff, stole ths idea, seen it many years ago I think on an early chevyII
