1960 Fairlane 500 rear window seal non Starliner
Hoping someone can help. I have a friend who is replacing his rear window for his Fairlane. He can not locate a replacement. He had tried all the normal outlets but is striking out. Does anyone know of a place that might have this? If he can’t find a replacement, he is thinking about buying 2 seals for a 61 tbird and cutting and gluing them together. He chose the 61 bird because the corners look similar.
Re: 1960 Fairlane 500 rear window seal non Starliner
I would call these guys up- https://www.steelerubber.com/steele-rub ... atherstrip
They aren't cheap but rubber is all they do. I'm sure they have a solution that will work.
Thanks Joe. Unfortunately he has tried them already with no luck
