TOOK IT off the lift in the shop after sitting for several months,,,all most started before battery played out...threw charger on it for about an hour,,,kicked off,,ran great,,drove to a monthly car gathering....ran just as good as it always has,,,,was a hit at the show...it posed for several pic's,,,and just a very few knew it was a comet and who built it.....POP
Today and for the last couple of weeks I have been chasing a “popping” in the LH exhaust when I decelerate from a cruising speed. I first went after the exhaust system figuring I had a leak that was introducing air into the hot exhaust when I let off the accelerator. I did find that the #5 header tube was not sealed to the exhaust port, I filed the flange flat and installed a new gasket, same problem, it still popped. Next I tried adjusting the carburetors, jet’s, progressive linkage,tuning, etc. no luck. The popping did lessen but it was still there. So I decided to check the advance on the distributor to make sure it was advancing correctly. I have my dampener marked for initial and total advance so I connected the timing light and confirmed that the advance was working just as it should. Next I checked the initial timing at idle, it was OK but I decided to bump it a couple of degrees. After readjusting the idle circuits on both carbs and setting the idle I took the car around the block. ( a five mile distance where I live) The car ran great! Good acceleration, and no more popping in the exhaust. This whole situation still has be baffled, I found no reason for it to all of a sudden become an issue especially when it only affect the LH side of the engine. Now I plan to go a little larger on the carb jets, my air/fuel ratio has leaned out slightly since I made the changes.
Fun with Cars!!
Fun with Cars!!
Today and for the last couple of weeks I have been chasing a “popping” in the LH exhaust when I decelerate from a cruising speed. I first went after the exhaust system figuring I had a leak that was introducing air into the hot exhaust when I let off the accelerator. I did find that the #5 header tube was not sealed to the exhaust port, I filed the flange flat and installed a new gasket, same problem, it still popped. Next I tried adjusting the carburetors, jet’s, progressive linkage,tuning, etc. no luck. The popping did lessen but it was still there. So I decided to check the advance on the distributor to make sure it was advancing correctly. I have my dampener marked for initial and total advance so I connected the timing light and confirmed that the advance was working just as it should. Next I checked the initial timing at idle, it was OK but I decided to bump it a couple of degrees. After readjusting the idle circuits on both carbs and setting the idle I took the car around the block. ( a five mile distance where I live) The car ran great! Good acceleration, and no more popping in the exhaust. I then drove the car about 20 miles at various speeds, no issues. This whole situation still has me baffled, I found no reason for it to all of a sudden become an issue especially when it only affect the LH side of the engine. Now I plan to go a little larger on the carb jets, my air/fuel ratio has leaned out slightly since I made the timing carb adjustment changes.
Fun with Cars!!
Fun with Cars!!
I get exhaust pop on both sides after hard deceleration (3K+>900). Plugs look good, may be a tad lean
Have fun
I checked my plugs also, they looked good. I thought I might have a lean condition also that is why I installed the air/Fuel gauge. The popping probably did not hurt anything but I found it very annoying, it reminded me of a “rice burner”.Joe Travers wrote: ↑Fri Aug 05, 2022 6:01 pmI get exhaust pop on both sides after hard deceleration (3K+>900). Plugs look good, may be a tad lean
Have fun
Did some maintenance work on the exhaust system this afternoon.
Blew the condensation out of the mufflers racing a rice rocket
Took the old gal out and stretched her legs this afternoon. The weather has been glorious, almost fall-like since hurricane Idaliah blew past. My wife and I drove to a nearby small town and back, about a 50 mile round trip. Not far, but more than the 5 to 10 mile trips to cruise-ins she usually gets. It was great to just roll down the windows and cruise at 55 down the blacktop.
Glad you got to get out w/ the wife, Jim.Jims65cyclone wrote: ↑Sat Sep 02, 2023 8:34 pmTook the old gal out and stretched her legs this afternoon. The weather has been glorious, almost fall-like since hurricane Idaliah blew past. My wife and I drove to a nearby small town and back, about a 50 mile round trip. Not far, but more than the 5 to 10 mile trips to cruise-ins she usually gets. It was great to just roll down the windows and cruise at 55 down the blacktop.
We finally got a good rain today down here after 10 weeks of drought. Temps finally getting back to normal after six weeks of 100F+ temps.
Called Russ today in Cali., have my other horn bracket on the way so I can breeze through inspection before end of October
Replaced the incandescent bulbs in stop and turn lights with LEDs. Much more visible.
Inspection??????Joe Travers wrote: ↑Sat Sep 02, 2023 8:51 pmGlad you got to get out w/ the wife, Jim.Jims65cyclone wrote: ↑Sat Sep 02, 2023 8:34 pmTook the old gal out and stretched her legs this afternoon. The weather has been glorious, almost fall-like since hurricane Idaliah blew past. My wife and I drove to a nearby small town and back, about a 50 mile round trip. Not far, but more than the 5 to 10 mile trips to cruise-ins she usually gets. It was great to just roll down the windows and cruise at 55 down the blacktop.
I kissed Mrs Pickles when I got back from Indiana and told her how lovely she was.
Found the new correct sun visors finally arrived for her.
Hoping to get the new headliner put in by the end of the year. Only two shops around my area and they are both slammed with work.
Yes, Doug but not as stringent as modern vehicles.
Well after 35 years together it is time to finally replace the quarters on my Cyclone. So that’s what I’ve been doing for the past week. Right side is about ready to go on but the left is going to take some rebuilding of the inner before it is ready for the skin. With any luck I hope to have her in 2k epoxy and the underside and front shot in black before it gets too cold here to paint.
Can anyone tell me what the max attachment size is?
Yes, Rootsy, we need to see some pics of your project. The easiest way to post pics is using a separate host, like Postimages. It automatically resizes your pics so they fit. This link will explain how to do it.
https://www.cometcentral.com/forum/view ... =1&t=16011
