body squeak
The Big Comets
fryedaddy
body squeak
Post by fryedaddy »
anyone ever heard of this.my 66 comet when you push down on the fenders my car would squeak.sounded like it was coming from the front inner fender area.it has done this for years,i thought it was the a frame bushings. heres the kicker,when i put my sub-frame connectors on the other day,it dont squeak any more. whats up with that?
fryedaddy
Ojohnny
Re: body squeak
Post by Ojohnny »
Mine has the same squeak, i figured it was the insulators under the front springs or the gasket between the back of the fender and firewall.
Re: body squeak
Bushings in the spring perch?
Re: body squeak
UCA bushings,,,,now that the connecters are in place,they do not let body twist and body flex and they have changed for lack of better way to say it.the tension points pop
fryedaddy
Re: body squeak
Post by fryedaddy »
im pretty stupid,what is the full name of those uca bushings?
fryedaddy
Re: body squeak
Upper control arm ,LCA is the lower control arm.
fryedaddy
Re: body squeak
Post by fryedaddy »
duh,anybody should have known that. im not much of a front end guy any way.thats the one thing i dont know enough about to trust myself working on.thanks everybody for your replys
fryedaddy
1966comet
Re: body squeak
Post by 1966comet »
My 66 has the same squeak. I found it between the front bumper where it attaches to the car. Just needs tightened.
fryedaddy
Re: body squeak
Post by fryedaddy »
my front bumper is a little loose. i will check that
fryedaddy
