Bench seat adjustment cable
I took my front bench seat to the upholsterer to get it recovered about a month ago. I am ready to install it but when I looked the cable that goes from the adjuster lever to the other side does not look right. It is all attached but he hog ringed it to the from of the seat frame. This does not seem right. Does anyone have a picture or can tell me how the cable is to be routed? I does not look to just go strait across as the tranny tunnel hump would press on it.
Thank you for any help you can give
Brian
Brian
Re: Bench seat adjustment cable
yes that's how mine was, hog ring was not tight so the wire can move. this keeps it from dragging in the middle.
Wow, ok, awesome.
Thanks a million.
I would be lost without this group!!
Thanks a million.
I said hog ring,but then got to thinking seems like I just unhooked from something when I took it off . looking at this illustration it shows a hook type thing which makes more sense,that way you could undo it if needed,& reattach easily. but I doubt that I would take the trouble to change the hogring unless it was too tight & wouldn't allow movement.
Here is a picture of my seat. The cable is seen at the far right. The lever is at the bottom along with the tensioner.
Looks good from what I’m seeing. I got a couple shots of mine, looks similar.
- Passenger
- 14EC2B2E-35B3-4559-9F1F-50D74DE9DC65.jpeg (127.68 KiB) Viewed 2598 times
- Driver side
- 9F73459E-00B8-4CE5-8F9B-79863630F8D2.jpeg (82.67 KiB) Viewed 2598 times
The best I can do right now. The wire has a little play, not much.
- 36C0E82E-FA87-4283-B2BB-3A53BD24163B.jpeg (113.9 KiB) Viewed 2585 times
- 02594181-FE7D-4327-8A5D-710CFB74C465.jpeg (78.02 KiB) Viewed 2585 times
Mine looks like it’s going through one ring, where yours looks like it goes through several. Like John said, “if it works leave it as is,”
I agree. Is it binding or is it operating smooth?
Perfect!!!! Exactly what I needed to see.
Thank you so much!!
Thank you so much!!
thanks everyone. Got the seat installed and it works perfectly.
