1966 drum to disc brake conversion
The Big Comets
Markunas1
Post by Markunas1 »
Hey guys,
I just got my wilwood disc brake conversion kit this weekend and started putting it in and figured id start a little thread and put some pics up for anyone else considering the swap. If I can figure out how to upload.
Re: 1966 drum to disc brake conversion
Markunas1
Post by Markunas1 »
Okay im going to give this photo upload thing a shot. I ran into a little issue and will be calling wilwood today, but I will go ahead and post pics up to now.
Here is what it looked like before the swap
Here is where I got when I realized I had a problem
And this is the problem, the edge of the caliper is in contact with the spindle and will not line up with the bracket....
Markunas1
Post by Markunas1 »
Okay well I called wilwood and got my situation fixed. Apparently I had my brackets on the wrong side... :oops: but its all good now. Got one side complete hope to finish the other side this weekend and be road ready! :mrgreen:
Lip Ripper
Post by Lip Ripper »
So my question is; does the disc set up use the same spindles as the drum?
Markunas1
Post by Markunas1 »
Yes. This kit is set up to attach to stock drum spindles or stock disc spindles. You do have to modify the disc spindles slightly though. Also clears 14 inch wheels
Lip Ripper
Hmm, I have a used set up that I pulled from a car that I parted out but it isn't Wilwood. It isn't stock either. How much was the kit? I have to buy another set of tires and wheels to go with what I have. (I think)
Markunas1
Post by Markunas1 »
I got it for 575 from jegs. Only kit I found with aluminum calipers that fit stock wheels.
Lip Ripper
Thanks. I checked to see what I have on the shelf and it is SSBC Force 10 calipers. It looks like they are on stock spindles too as I compare them to mine. I emailed SSBC to see if I can buy kits for them since a couple of dust boots are torn. I pulled the stainless lines and proportioning valve from the donor car too. Heck they may clear 14's I'll have to check.
Stacey
Markunas1
Post by Markunas1 »
Yea they might. Most of the stuff from ssbc (that I could afford) required 15 inch wheels, unless it had cast calipers
Markunas1
Post by Markunas1 »
Yeah thats one thing I didnt get though is a new proportioning valve. Is that a necessary part to change when going from drum to disc?
Lip Ripper
Yep. And you have a dual master cylinder now, right?
Markunas1
Post by Markunas1 »
No I guess i will have to purchase that stuff before I can drive... any sugestions as far as what would need the least modification?
Comechero65
Post by Comechero65 »
Lip Ripper wrote:Thanks. I checked to see what I have on the shelf and it is SSBC Force 10 calipers. It looks like they are on stock spindles too as I compare them to mine. I emailed SSBC to see if I can buy kits for them since a couple of dust boots are torn. I pulled the stainless lines and proportioning valve from the donor car too. Heck they may clear 14's I'll have to check.
Stacey
My front disks are the K-H 4 piston calipers from a 67 mustang. I think SSBC sells the same parts. Stock 14" wheels as well as the 14" rims I am using mount and clear with no problem.
Flintlock
Post by Flintlock »
I bought this kit and it bolted right up to my 65 (5 bolt spindles) with zero problems. Includes the dual master cylinder as well. http://www.chockostangclassicmustang.co ... sions.html
Mark
