carnage & mayhem in Gulfport
Posted: Thu Sep 15, 2011 5:37 pm
by juddp39532
Well I went to test the new carb last night at Gulfport and it bogged at the 3800 I normally launch at (11.92 1/4mile 1.76 6o') so I tried 4,000 rpm an the next run. The Comet jumped out then pop and it ran to the right. I just dissassembled it and one Moser axle is twisted while the other snapped and destroyed the bearring adjustment ring on the center section. #$%&^!!!!
Re: carnage & mayhem in Gulfport
Posted: Thu Sep 15, 2011 6:52 pm
by Boss/Cyclone
Sorry to hear of your problems Judd, I know how it sucks to break at the track. At least you didn't put it into the wall. Got any pics of the twisted up axleshaft?
Posted: Fri Sep 16, 2011 1:46 am
by CALIFORNIA CALIENTE
I DO NOT like Moser axles!!!! I broke one that destroyed the right quarter and the trunk aluminum pieces.I run Big bearing 35 spline Mark Williams axles,actually the whole rear end is MW!! It sounds like you are making good power though!! ROY.
Posted: Fri Sep 16, 2011 10:49 am
by Boss/Cyclone
CALIFORNIA CALIENTE wrote:I DO NOT like Moser axles!!!! I broke one that destroyed the right quarter and the trunk aluminum pieces.I run Big bearing 35 spline Mark Williams axles,actually the whole rear end is MW!! It sounds like you are making good power though!! ROY.
I have the 45 degree 35 spline Mark Williams axles in mine. Probably overkill for a 11 second car but I hope to test their strength next season.
Posted: Fri Sep 16, 2011 12:12 pm
Larry;at least when you hammer it you don't have to worry about axles!!I pull my axles at least once a season to check for twist,so far so good!!!ROY.
Posted: Fri Sep 16, 2011 3:19 pm
by juddp39532
Well I took the scrap iron to my rear end man and he thinks he can have it back together for the race next week end. I was still running the 28 spline the guy I bought it from had it it but it will be 31 spline spool now ( biggest I can go with small bearing housing). I hope it holds up as I don't want to change the housing!
Posted: Fri Sep 16, 2011 5:35 pm
by Boss/Cyclone
CALIFORNIA CALIENTE wrote:Larry;at least when you hammer it you don't have to worry about axles!!I pull my axles at least once a season to check for twist,so far so good!!!ROY.
That was my thought, spend some extra now, pays off later.
Posted: Fri Sep 16, 2011 11:55 pm
by b.guggenmos
Mark Williams 35 spline for me also. I broke 28 and 31 spline stuff way to many times. I bought my MW axles in the mid 1980's and they are absolutely perfect still. Same spool also. A couple ring and pinions and I still use a Ford N case. Some day I will upgrade to a Mark Williams housing and carrier but I am pretty good now. Roy's problem with the Moser was bad. It could have totaled the car. Brian
Posted: Sat Sep 17, 2011 1:21 pm
by Boss/Cyclone
I sold my factory 1969 dated N case a couple years ago for a enough money to get 2 modern big bearing N cases.
The money some will spend on even small details to make their cars factory correct is unreal.
Posted: Sat Sep 17, 2011 11:56 pm
Judd;with yours and my luck lately we must have really ticked off the Mercury Comet Gods!!!!! I'm begining to think my Comet does not want to run quicker than before!!!! I hope you can get back up and running quickly!!! ROY.
Posted: Sun Dec 14, 2014 8:59 pm
by Tbart
This is down the hardcore scale a little,but I'm thinking of cut to fit 28 spline axles from Speedway for my 351w Falcon. My initial setup was a 59 Galaxy rear in which I used 4.57 gears and a mini spool with the stock 59 axles. I was running 13.10s20s to just shake the car down at 5600 or so rpm. All seemed well so I left harder and shifted at 6200 and ran 12.9s. This engine builds power to 7000 so up I went to 6300 and at my 1-2 shift the pass side 59 axle broke under the cap. The mini spool and stock pin were all that survived. I put them into a stock 57 Edsel case with stock 3.56 gears and another set of stock Edsel axles. The car still runs 13s and I dare not exceed 5600 rpm. This has made me a better bracket racer actually but is getting kind of lame. I have a good case and a new set of 4.11s. I think mini spools are tough enough for me and are cheap. 28 or 31 spline. What kind of axles should I get that will fit my 59 Galaxy rear? Small bearing? Big? Is there an offset difference? I'd like to go racing again in April without worry about my axles in the mid 12s. I'm kinda cheap too.
