Upgrade your steering ( 65 V8 steering)
Re: Upgrade your steering ( 65 V8 steering)
I would say yes simply because 65 disc brake stuff fits a 64 which is same as 63.5.
I think the only difference between the two spindles is the location and hole size of tierod mount.
to add to what fred said,on the CSRP brake page under ''compatibility'' on the swap 1 kit it says their brakes fit 63-65 & (60-62 as well with 63-65 UCA replacement)
so if that is true then hubs/drums from all of those years should fit each other too.
