Hi,
Originally my 67 Caliente was 289/C4 it is now 351/C6. The PO installed a Lokar floor shift (which is a little too "street rod" for my taste) but kept the OEM column.
I am wondering if anyone has a solution to using the original column with a C6. My understanding is that the C4 linkage will not work.
Thanks
How to Use C4 Column Shift With C6
- IMG_2468 (2).jpg (68.5 KiB) Viewed 1278 times
Re: How to Use C4 Column Shift With C6
It won't work the way it is but with creative bending and lever length and position adjustments you can make it work.Did mine and it worked great...and that was with a 460 with headers.
