This is from a post over on Tffn done by a guy that has been in the wheel alignment trade since '71 so should know. Thought it was good info to have here.
" I did some research several years ago when I was contemplating the change to five-lug Wheels, on my '65 Falcon Sedan. I discovered within the Ford Master Parts Catalog that the geometry remained the same for V8 Falcon, Fairlane and Mustang Spindles, from 1965 through the 1969 model year, along with their Mercury counterparts.
'65 through '69 Spindles (C9OZ-3105-C & C9OZ-3106-C) are used for Drum Brakes for all those years, as well as the Kelsey-Hayes four-piston Disc Brake Assemblies used in 1965-67.
'68 and '69 Spindles (C8OZ-3105-A & C8OZ-3106-A) have the same steering geometry as the above part numbers, but are not compatible with Drum Brake installation. They are designed specifically for the single-piston Disc Brake setup, that Ford began using at that time.
Upper Control Arms are interchangeable for '65/'66 Falcon and Mustang, but beginning in 1967 the distance between their mounting Studs became greater (for Falcons, Fairlanes and Mustangs), so they won't align with the holes in the Spring Towers of the earlier models.
Rick"
Front suspension interchange.
Re: Front suspension intetchange.
Over the Summer I helped my Dad cut out the shock towers out of his 65 Cyclone. Replaced them with 69 Mustang shock towers, 69 Mustang upper and lower control arms, steering column and steering box. 66 Mustang draglink and tie rod ends. Now it looks stock to most people, but a big block bolts right in.
- dadsshocktowers.jpg (110.49 KiB) Viewed 2775 times
Nice modification. It sure makes more room for the big block. I read an article a while ago about an install similar to yours but in a early mustang, but I believe the owner kept the small block.
I did something a little different, I kept the factory shock towers but sectioned them a few inches. This gave me quite a bit more room for the Boss engine. I see you changed the steering box also, mine now has a ‘68 Cougar box.
Great work on your Dad’s Comet.
A local guy did the same as you in a 64 but he didn't do it as cleanly as yours looks. My 65 I just cut the shock towers and welded in flat metal. I did not buy a kit, just made everything. Made working on my Boss 351 much easier than when the shock towers where in there. My Dad wanted a more stock look.
Here is the engine bay of my 65
A/FX wrote:Nice modification. It sure makes more room for the big block. I read an article a while ago about an install similar to yours but in a early mustang, but I believe the owner kept the small block.
My Dad is putting a Boss 302 in his. I'll get a picture next weekend. He just wanted the space and possibility of a fe some day.
The Boss 302 does fit without the modifications but it is a real tight fit. I installed the Boss in my Cyclone back in 1972.Boss/Cyclone wrote:A/FX wrote:Nice modification. It sure makes more room for the big block. I read an article a while ago about an install similar to yours but in a early mustang, but I believe the owner kept the small block.
What headers is your dad planning to use? I bought a pair of JR headers back in ‘72, I just had them jet coated, they are going back into service this time around.
The stud girdle valve covers on your 351 are unique, I just sold a NOS pair of Of them not too long ago.
Re: Front suspension interchange.
He has headers we bought from Vermeesh at total performance back in the early 90's. My brother had the boss 302 in a 65 Falcon sedan back then. The stud girdle valve covers I bought them new back in the 80's. Surprisingly felpro still makes the special valve cover gaskets for them.
picture of my Dad's boss 302, should be back in his 65 Cyclone next week
- boss302 - Edited.jpg (62.8 KiB) Viewed 2603 times
That Boss engine looks great! I will bet it will sound even better. What valve covers will it have? I have Crane roller rockers in mine and had to use spacer plates to raise the stock aluminum covers in order to clear the rockers. (The drip rails interfered)Boss/Cyclone wrote:picture of my Dad's boss 302, should be back in his 65 Cyclone next week
He has some aftermarket tall finned aluminium valve coversA/FX wrote:That Boss engine looks great! I will bet it will sound even better. What valve covers will it have? I have Crane roller rockers in mine and had to use spacer plates to raise the stock aluminum covers in order to clear the rockers. (The drip rails interfered)Boss/Cyclone wrote:picture of my Dad's boss 302, should be back in his 65 Cyclone next week
https://www.atracingworld.com/Ford-302- ... all-w-Hole
