Neutral Safety Switch wiring: 64 Comet
Getting close to actually pulling the engine, (64 Caliente, 289, C4, column shift) Scraped about 20 lbs of crud off the bottom of the car to get to all the fasteners, etc. So the question is about the Neutral safety switch: where does the wiring go, physically, from the actual switch ? Looking for where it disconnects from the main wiring loom. Removing the bottom crud didn't do much for the spider webs between the drivetrain and the body, and I can't see where the wire goes.
Re: Neutral Safety Switch wiring: 64 Comet
Under the hood on the fire wall,,4wire plug in,,it also contains back up lights wires,,you will see them coming from trans up ward.....good luck...POP
Got it ! Thanks !popscomet wrote:Under the hood on the fire wall,,4wire plug in,,it also contains back up lights wires,,you will see them coming from trans up ward.....good luck...POP
