Rear end locked up
Re: Rear end locked up
I got the center section back from the shop. Decided to go with posi and 3.55 gears.. Why not huh? This time I think I will add gear oil Still a little sore the shop didn’t alert me to add oil the first time.. Water under the bridge.. got it all installed. now a test drive when weather permits.
- BFD2E71E-94C1-4C99-8AC3-99F6C289ABD3.jpeg (114.41 KiB) Viewed 425 times
- 8FCEAF4D-783E-47D7-84E9-8DEF4115D538.jpeg (115.21 KiB) Viewed 425 times
- A05FADCD-E20D-49FB-AE39-5A9E1AB8FE63.jpeg (118.31 KiB) Viewed 425 times
JMO,I think a 3.55 gear ratio is the best all around gear to have under anything you drive on a daily basis....good luck and be sure you add the correct lube ....pop
