260 V8
260 V8
I recently bout a 1964 Comet Wagon that has a 260 engine in it. I was going to switch it out for a 302. I drove the wagon home so the motor is still good. Is the 260 worth anything? Or is it worth keeping it in there and just adding some new stuff to it? Thanks!
Re: 260 V8
you are aware the bellhousing is different between 260 & 302 ?
Re: 260 V8
Speaking as the driver of a 260, it's the BEST engine Ford ever made!
Ok, but seriously, is the 260 all original or modified? Does it have a 2 bbl or 4 bbl? is there anything wrong with it?
Why do you want to swap to the 302? Sure the 302 is going to make more hp and torque, but it all depends on what you want out of the car.
Re: 260 V8
The previous owner said it is all original but I haven't pulled it yet to see. I just want it to be a cruiser. I plan on putting a set of headers on it and would like a mild cam, aluminum intake, etc. Nothing drastic just freshening up. It has a 2 barrel carb on it now but I would like to install an efi system on it. Yall's thoughts?
Re: 260 V8
What Trans is in it? If it's a Mercomatic 2 speed, the 302 wont bolt up. If it's a C4 it's a 5 bolt Bell Housing and only a Early 5 bolt 289 will bolt up. If not you'll need a 6 Bolt C4 to go with your 302. Do not bolt a 5 bolt 289 to the Mercomatic, The 2 speed is junk compared to the C4. I just did a 289 / C4 Mod to my '63 260/Mercomatic. Much better torque / Drivability
Re: 260 V8
Man, that looks nice! It has a C4 transmission in it.
Re: 260 V8
If it doesn't have any blowby and has good oil pressure, I'd keep it in there and do something like a Shelby tune-up.Proverbs27:17 wrote: ↑Wed Oct 21, 2020 2:19 pmThe previous owner said it is all original but I haven't pulled it yet to see. I just want it to be a cruiser. I plan on putting a set of headers on it and would like a mild cam, aluminum intake, etc. Nothing drastic just freshening up. It has a 2 barrel carb on it now but I would like to install an efi system on it. Yall's thoughts?
Re: 260 V8
let POP set the record stright....the bell houseing on a C4 bolts on ,,you can unbolt the 5 bolt bh and bolt same tranny to a 6bolt bh......the orignal c4 out of my 64 5bolt comet,,,is today bolted to a 6bolt bh which in turn is bolted to a 1976 351w...
Re: 260 V8
The 260 is a fine "little" motor. I have one that came from my 63 Comet. I rebuilt it with .020" over pistons. To that I added a 212/212 Comp hydraulic cam, barely over stock, a 108 Autolite carb and a cast iron Ford 4bbl intake. It has an early C4 (Green dot/White dot) with a 3:25 eight inch rear. It runs very well. The secondaries take awhile to open as there is not much carb signal even at 2500/3000 RPM, but they do open and it can be felt and they stay open as long as you on the gas pedal. I am using stock Comet exhaust manifolds and they limit the usable RPM to 5100. I know this is blasphemous, but this motor is in a 63 Rambler American, which weighs about 2520 LBS and turned 15.4 seconds in the quarter. Not much slower than the stock GTO, etc. of the era. So, while the 260s won't set the track on fire, the one I have does a decent job. If your motor needs to be rebuilt, it will serve your car well and be a great cruiser.
Re: 260 V8
and that's not to shabby in my book,,,,and I 100% agree with the above,,,,you do not need a snot gobbler to cruise around in...JMO.....I think somtimes guys watch to much TV and read way to many magazines and again this is JMO....POProbib wrote: ↑Wed Oct 21, 2020 7:47 pmThe 260 is a fine "little" motor. I have one that came from my 63 Comet. I rebuilt it with .020" over pistons. To that I added a 212/212 Comp hydraulic cam, barely over stock, a 108 Autolite carb and a cast iron Ford 4bbl intake. It has an early C4 (Green dot/White dot) with a 3:25 eight inch rear. It runs very well. The secondaries take awhile to open as there is not much carb signal even at 2500/3000 RPM, but they do open and it can be felt and they stay open as long as you on the gas pedal. I am using stock Comet exhaust manifolds and they limit the usable RPM to 5100. I know this is blasphemous, but this motor is in a 63 Rambler American, which weighs about 2520 LBS and turned 15.4 seconds in the quarter. Not much slower than the stock GTO, etc. of the era. So, while the 260s won't set the track on fire, the one I have does a decent job. If your motor needs to be rebuilt, it will serve your car well and be a great cruiser.
Re: 260 V8
That's the ticket, power to weight ratio. Why I love the Comet.
GTOs weigh 1/2 ton more than the Comet. Comets don't need a ton of power to compete with higher horsepower intermediate/full size cars.
260s were scooting pretty fast in Shelby's rally cars and the early Cobra. It's a keeper.
I found a '63 260 last month and I have my eye on it. It's not going anywhere until I can get a new shed built out back.
Re: 260 V8
Snot gobbler!
I think the 302 in my Falcon qualifies as a snot gobbler!!
Re: 260 V8
or maybe a snot slinger
