I ordered new sway bar endlinks from Suspension.com. The site specifically said for 1961 Mercury Comet, but alas they do not match up to the original.
The through bolt is about 3/4 inch shorter on the new ones. the spacer sleeve is shorter, so when lining up the bottom, new with old, it puts where
the sway bar attaches about 1/2 inch lower than the original. Is this an issue to worry about? Thought I would ask here. Tried to post a picture, but not sure how to do it, or where i would find instructions.
Thanks in advance.
61 Comet base, sway bar end links
Re: 61 Comet base, sway bar end links
I don't think it will be a problem.
It should work but you could easily substitute longer bolts and sleeves. In the future I would suggest using a name brand supplier instead of a .com fly by night outfit. (NAPA parts are always first quality.)61 Waycrosscomet wrote: ↑Sat Nov 28, 2020 5:33 pmI ordered new sway bar endlinks from Suspension.com. The site specifically said for 1961 Mercury Comet, but alas they do not match up to the original.
Thanks in advance.
If it doesn't suit you,you could use your old bolts & sleeves with the new rubber & washers. hit em with a wire brush ,coat of rattle can paint.
Thats what I am thinking of doing. Just waiting to hear what the vendor I bought them from says.
The pic was more of a test to see if I could post a picture. And it worked pretty easily.
