AOD trouble
Posted: Sun Feb 28, 2021 7:05 pm
Im having trouble with my AOD not having any movement, seemingly randomly, and working fine other times. Long winded post, but im trying to be as detailed as possible.
Story goes, I bought this trans used. Fellow said it came out of an 88 F150 with a 5.0L. It was marked 168K (Kilometers, roughly 100k miles) and he said the truck was wrecked and thats why it was pulled. I got the flywheel and block seperator plate with the trans all for a couple hundred bucks.
When I bolted the trans up to the engine, I made sure the torque converter was all the way engaged. The trans bolted all the way up to the block without binding and the torque converter was not jammed into the flex plate, so I do not believe that Ive just missed the pump engagement (though when the rain stops im gonna go double check).
When I was first running the engine, I had no shift linkage, cooler lines, or driveshaft. So for the first few runs of the engine, I had the trans in park, the cooler lines just looped, a driveshaft yoke stuck in the end of the trans, and enough fluid to show on the dipstick. It was run maybe a total of 45 minutes like this. When I made the cooler lines and shift linkage, and got the driveshaft in, I fired it up and all was well. In topping up the fluid, i needed another quart or so, so I shut the car off and dug out another quart. Fired it up and topped it off, and then no engagement at all. Tried a few things with no luck. I later tried some lucas stop slip just for fun with no luck.
So I pulled the pan, changed the filter and cleaned out all the lucas that had settled in the pan. The fluid looked ok coming out and there didnt seem to be an abnormal amount of clutch material in the pan or anything. Cleaned everything and put it back together, filled it up, and I had engagement again. Everything worked. I was out of ATF and still a couple quarts low, so I shut the car off and left it a few days. Few days go by, I pick up some more ATF and tried it, now when running the dipstick shows over full, when a few days ago it showed low still, and I have no engagement at all. If I start it in gear with the rear end jacked up, It will spin a wheel for a couple seconds with no real force, and then thats it. Its almost like the pump isnt pumping, but that doesnt explain why it works sometimes and not other times.
Hoping someone with more experience than me with the AOD trans can chime in. My goal is to exhaust all possibilities before I pull the trans and have it rebuilt.
