Torque specs for trans. install
lazer
Post by lazer »
I have a 66 comet 390 4 speed could someone tell me the torque specs on the bellhousing and pressure plate? I found pressure plate 35 lbs and bellhousing 40-5- and trans to bell 37-42 lbs are these right/ Different places give you different numbers. Thanks.
Re: Torque specs for trans. install
don't forget .....a few drops of LOK-TIGHT on pp bolts,,, on bell houseing bolts not as important, ,and I always smear anti-seiz on input shaft spline and on end to go into pilot shaft bushing good luck pop
lazer
Post by lazer »
Thanks for the tips, I've never done this before but it's going pretty smooth so far. The biggest problem that I had was the top bolt on the starter, I had to get a 2' extension and go in through the front of the engine.
join the crowd :!: :wink: good luck.....you gonna do just fine................pop
fryedaddy
Post by fryedaddy »
dont go past 35 on the pp bolts.i snapped one off at 40 one time thinking they torqued at 45,wrong! is your comet a factory 390 4 speed caliente or cyclone
fryedaddy
lazer
Post by lazer »
It's a '66 390 3 speed stock, I thought. Ran into a problem, went to put on the 11" pressure plate and the holes wouldn't line up on the fly wheel. I looked at the old PP and it's a 11 1/2" I ordered a new fly wheel, same amount of teeth, so I hope this all fits.
