Pedal Pivot Accelerator Linkage
I have a 1965 Caliente 289 4 speed. I want to swap the stock accelerator pedal with a Mustang pedal but the Comet linkage doesn't have the hole to accept the Mustang pedal. Does anyone know if the stock Mustang linkage can be used on the Comet?
Re: Pedal Pivot Accelerator Linkage
Your picture didn't come through, Roadie. Be sure you press the copy button to the right of the "Hotlink for forums" option in Postimage. That will copy the link for you. Then you just paste the link into your message. When you click on Preview button the picture should appear. Then go back down to the compose window and click on the submit button.
