Page 1 of 2
Lower control arm
Posted: Sun Mar 13, 2022 2:45 pm
by JCBond
Can someone tell me how these washers/caps go on.
- IMG_2969.jpg (103.89 KiB) Viewed 2136 times
Thanks
Re: Lower control arm
Posted: Sun Mar 13, 2022 3:08 pm
They may be for the sway bar's end links.which goes in that hole above the little piece of a leaf. Cant think of any where else they would go. make sure you take off the blue shipping cover.
Posted: Sun Mar 13, 2022 3:35 pm
by SASSY
Once you take the shipping cover they may go under the spindle on the ball joint rubber cover.
Post a pic with the shipping off,,,
Posted: Sun Mar 13, 2022 4:06 pm
by JCBond
By the way thanks for telling me that was shipping. I would have left it on.
And also these struts rods, I'm getting new ones but I was just curious. The upper one has two sets of threads and the lower just one. The upper, I suppose is, not the original?
- IMG_2970.jpg (66.13 KiB) Viewed 2129 times
- IMG_2971.jpg (135.93 KiB) Viewed 2129 times
Posted: Sun Mar 13, 2022 8:55 pm
Yea looks like an earlier adjustable type & a later non adjustable rod. but junk now for sure what ever they are. Be a good time to put adjustable ones on but they are higher. but could be made at home cheaper, that's what some of us did. adjustable strut rods makes the car a lot easier to align up.
what year is the car?
Posted: Sun Mar 13, 2022 9:10 pm
by JCBond
poboyjo65 wrote: ↑Sun Mar 13, 2022 8:55 pm
1963. Could you point me in the direction of ones you recommend.
Posted: Sun Mar 13, 2022 9:54 pm
Well the sky is the limit. depends on what you want from the car & what you want to spend or if you want to build your own . opentracker is one vender who sells them & may sell a kit to make them.
Right or wrong I put those washers on the end links,found some pics to help my memory. I put one on top of the lca cupped up under the rubber of the endlink, & I put one on bottom cupped down then a big flat washer,then nut. kinda lets it lean when it needs to.
this pic from inside the engine bay but you can see the washer cupped up
Posted: Sun Mar 13, 2022 11:16 pm
Did a quick search, these look pretty good for the money;
https://www.cjponyparts.com/specialty-p ... 4-EALw_wcB
but I'd shop around if it was me.
Posted: Mon Mar 14, 2022 11:12 am
by SASSY
Got my adjustable strut from Melvins classic Ford
By the time i got it shipped to Canada $ exchange + duty !!!
Posted: Mon Mar 14, 2022 7:52 pm
by JCBond
This sway bar has the original bushings (or I should say original when I got it). I was wondering if I should replace them. Do they make that much difference in the steering? They seemed a little hard to find and match up.
- IMG_2982.jpg (122.54 KiB) Viewed 2059 times
Posted: Mon Mar 14, 2022 8:31 pm
by Jims65cyclone
Definitely replace them while you've got it apart. They're cheap, and no better time than now.
https://www.rockauto.com/en/catalog/mer ... shing,7624
While you're at it, replace the stabilizer bar end links and bushings. Also cheap.
Posted: Mon Mar 14, 2022 8:44 pm
by JCBond
Thanks Jim. So when you order them you measure the diameter of the sway bar?
- IMG_2983.jpg (106.54 KiB) Viewed 2050 times
Posted: Mon Mar 14, 2022 11:04 pm
by Jims65cyclone
On the link I included, I used a 260 CI engine since I didn't know what you had. You can click on whichever engine you have, and it should look up the correct part for you. Not sure if there's a difference in bushing size between the V8 and the I6 or not.
Posted: Tue Mar 15, 2022 10:43 am
by Joe Travers
JCBond wrote: ↑Mon Mar 14, 2022 8:44 pm
That's a '63 260 sway bar. Jim's link is correct.
Posted: Tue Mar 15, 2022 4:57 pm
here's some better pics of the cupped washers;
seems like I remember the original LCA had these cup like washers made into the LCA. but I dont always trust my memory anymore
