c4 to fe motor
loman
c4 to fe motor
Post by loman »
Just curious if anyone has seen the adapter in the link below and what their thoughts were on it.
https://www.transdepot.net/feadapter
Re: c4 to fe motor
It looks like a quality piece. Probably need it if you want to retain the factory trans tunnel as a C6 won't fit in that tiny 65 tunnel. I have used adapters in the past to put a 5r55 on to a 400M in a 1978 f150 and it worked fine.
loman
Re: c4 to fe motor
Post by loman »
I have a c6 on my 390 with a modified tunnel in my car. Was just thinking a C4 would be a lot smaller and not rob as much power as the C6. Of course than I would have to build a C4, buy torque converter, and buy a new drive shaft.
Re: c4 to fe motor
loman wrote:
Fri Dec 23, 2022 12:59 pm
You're probably right, did not know what you are after. Getting every bit of power to the ground or cool cruiser where c6 or c4 doesn't matter much.
Re: c4 to fe motor
loman
Re: c4 to fe motor
Post by loman »
Thanks Boss, I have looked at those. That would be my first choice in bell housing. I was just doing a little day dreaming.
